Need help! Brake issue!
Old Jun 19, 2020 | 07:59 PM
Chavez_zee33's Avatar
Chavez_zee33
Default Need help! Brake issue!
Hey everyone, I replaced my rear brakes, calipers and rotors today and also bled the brake system. I had to replace them due to a caliper locking and rotors needing to replaced anyway. I had some trouble with the rear right caliper bolts not going all the way but eventually got it down. I also had a caliper piston (old) jump out and shoot brake fluid everywhere.
Anyway after finishing the job I put the wheels on and turned the car on to move it into the driveway when the brakes went from being firm to straight to the floor with a sort of pop sound each time. I also noticed the brake light is on as if the ebrake was on which it wasn't. I'm sure I did the process right I've always done my brake jobs but this was the first time doing my 350z's and i can honestly say I struggled a bit. Any advice would be appreciated, also the front was not done since I ran out of time and I will not be moving it till about a week. Thanks in advance guys 😣
Old Jun 19, 2020 | 09:19 PM
jhc's Avatar
jhc
General & Tech Moderator
1st thing I'd check is make sure all bleed valves are tight. Your brake light is on likely bc low fluid level. Gl!
Old Jun 19, 2020 | 09:26 PM
Chavez_zee33
Thanks bud! I'm gonna take a look at that and I've been seeing my fluid might be low I'll have to check it out
Old Jun 20, 2020 | 12:54 AM
DarkZ03's Avatar
DarkZ03
Bleed the system again with a motive bleeder, probably have air in there.
kauai1800
Apr 27, 2018 08:41 AM
Xx AzN xX
Mar 16, 2013 03:54 AM
lemmiwinkz
Dec 10, 2009 10:01 PM
marques1
May 27, 2009 06:05 AM
Sep 18, 2008 12:55 PM
