Emergency brake shoe issue
Old Mar 14, 2013 | 09:37 PM
Xx AzN xX's Avatar
Xx AzN xX
Default Emergency brake shoe issue
Ok long story short i took my rotors off and when i tried to put it back on it wouldnt fit because the brake shoe was expanded i guees. I needed to go so i just took the whole shoe off. Does anyone have a diy on how to put it on? Is there a infiniti guide? Please help thank you.
Old Mar 15, 2013 | 08:54 AM
jhc's Avatar
jhc
General & Tech Moderator
I would be super careful, drum brakes are more difficult than disc. Springs can fly off and poke your eye out. You'll prob need to compress the wheel cylinder with a clamp, and shorten the tensioner stud for e brake. YouTube search 'drum brake pads.' Good luck.
Old Mar 15, 2013 | 09:07 AM
Bret86944's Avatar
Bret86944
I know little about drum brakes, but I do know the little cylinder at the top of the picture with the teeth can be turned to loosen or tighten the brake.
Old Mar 15, 2013 | 10:29 AM
terrasmak's Avatar
Chinese repair Manuel , take the other rotor off and look. That's what I did the first time when I struggled
Old Mar 15, 2013 | 02:53 PM
stascom's Avatar
stascom
Chinese repair Manuel ...
Manuel is Spanish
Old Mar 15, 2013 | 04:18 PM
terrasmak's Avatar
Originally Posted by stascom
Manuel is Spanish
autocorrect on phone
Old Mar 16, 2013 | 02:56 AM
jerryd87's Avatar
jerryd87
lol what they said put them back and spin the cylinder to make the shoes move in closer to each other. once you do that there should be a plug on the back of the dust shield that you can stick a screw driver in to adjust it back out until there is just a little bit of drag from the shoes.
Old Mar 16, 2013 | 03:54 AM
Lawn Dart's Avatar
Lawn Dart
Drums are easy. Install the drum over the shoes with the adjusting washer all the way in. I usually leave it a half a thread out, because it's easier to turn if it's not tight. Pop the rubber plug off the drum and rotate the axle until you can see the adjuster. Turn it with a screwdriver until it tightens all the way. Then, back it off one tooth.
350z82
Oct 1, 2015 06:25 PM
