True style coilovers - reinforcement for racing?
Old Aug 13, 2025 | 09:55 AM
Mattedg_man's Avatar
Mattedg_man
Default True style coilovers - reinforcement for racing?
Has anyone who races their z found they need to reinforce the rear shock towers when moving to true style coilovers? Springs I'm planning to use in the rear would be somewhere around 8-9k.
Thanks
Old Aug 13, 2025 | 02:03 PM
terrasmak's Avatar
If your running a 8 to 9k spring as a true coilover , you are probably running a 20k up front and on 300ish width slicks all around. Just run an x brace in your rear downtubes off the main hoop and triangulate from the lower part of the hoop to the tower
Old Aug 14, 2025 | 02:26 PM
dkmura's Avatar
dkmura
General & DIY Moderator
I'm also of the opinion that 8-9K springs on the rear is overkill. After years of racing the Z33, you need some rear compliance to control wheel hop and oversteer.
Old Sep 3, 2025 | 10:06 AM
Mattedg_man
Whoa late response guy here. What would be your recommendation for rates then? I see a lot of ppl recommending/running 10k front 6-8k rear. I'll include some more info for a bit more context.
Current setup: Koni yellows with swift spec r springs. 275/35/18 tires on all 4 corners. Tire width and wheel size will not be changing anytime soon.
I plan on moving to a true style coilover and ditching the divorced setup.
I primarily use the car to autocross and the occasional track day/tt. I dont daily the car or really drive it much at all outside events. I'm looking to get a set of nice mid-range coilovers this offseason to hopefully make the car a bit more competitive at autox as it already does surprisingly well.
Thanks
Old Sep 4, 2025 | 12:19 PM
terrasmak's Avatar
12 to 16k fronts , depending on tire compound and aero , with a 5k rear
aftermarket front bar , stock rear , remove an end link in the rear if you need more traction for auto cross
Old Sep 5, 2025 | 05:49 PM
Mattedg_man
No aero, running super 200s. Vitour P1s. I do have a hotchkis front bar. Using the stock rear still for now
Old Sep 8, 2025 | 06:04 PM
terrasmak's Avatar
14front , 5 rear
stagger hole 2/3 on the front bar
-3 front camber , -2 rear
great starting point
Z_Ph3nom
Suspension
Apr 29, 2014 07:42 PM
User 42426
May 29, 2013 09:16 PM
all star gene
Suspension
Sep 22, 2011 08:24 PM
Yawick
Jun 5, 2009 03:45 PM
GamblerZ
Nov 21, 2006 09:38 AM
