Can I fix Skyline brakes??
Old Mar 6, 2004 | 08:03 AM
Bahraini350Z's Avatar
Bahraini350Z
Question Can I fix Skyline brakes??
I have found Nissan Skyline GTR r33 Brembo brakes. Can I fix it on my non-Brembo Touring Z?? Will I be needing the whole brake lining with it or only the discs and calipers will do?? Has anyone performed such a task??
Thanx
Old Mar 9, 2004 | 07:16 AM
Bahraini350Z
wow!!!!!!!!! no one here can help me with that!! all this time and not a single reply
Old Mar 9, 2004 | 08:14 AM
azrael's Avatar
azrael
I believe it will all fit, but you might need a custom mounting bracket.
Old Mar 9, 2004 | 08:43 AM
bobowah's Avatar
bobowah
the R33 brakes are basically Z32 brakes..
but yes you can make them fit you will need some custom bracket made..
good luck... might be easier to sell those to a 240sx guy...
Old Mar 9, 2004 | 11:26 AM
John's Avatar
John
From what I understand, the rotor offset on the Skyline Brembos is 5mm different than the Z33's OEM Brembos. Not sure if the caliper is the same or not.
Old Mar 9, 2004 | 12:09 PM
apsilon's Avatar
apsilon
You're correct John, the rotor is different which means the caliper bracket is also different.
Old Mar 18, 2004 | 10:02 AM
Bahraini350Z
Thanx guys...... but, can I or not??!! what mods do I need to perform in order to achieve this??!!
Uriyo_
Sep 8, 2021 08:46 AM
07ZEKE
Aug 23, 2021 09:15 PM
