Just got my track Brembos, need some questions answered
Old Mar 12, 2004 | 03:14 PM
benzz280's Avatar
benzz280
Talking Just got my track Brembos, need some questions answered
http://www.imagestation.com/album/?id=4287459921
Man are they huge and heavy
No plan to install them yet, but for sure they will be on my car before my BlackHawk event with the Lotus corps
By the way, the questions are on the pictures. Hopefully those who had swapped them before can provide some insights. TIA.
Dont be jealous (jus kiddin')
Old Mar 12, 2004 | 04:30 PM
2003z's Avatar
2003z
I;ve done the swap for someone. That bracket doesn't look familiar. Are they actually from a Z? The nut on the front is also on your non-brembo Z, its to keep the rear wheels from being mounted on the front hubs. you can remove it.
Old Mar 12, 2004 | 05:43 PM
Michael-Dallas's Avatar
Michael-Dallas
The bracket looks like the mount for the brake line junction block. The brake line is segmented w/ a metal "junction block."
Michael.
Old Mar 12, 2004 | 07:07 PM
benzz280's Avatar
benzz280
Are you referring to the the front rotors? Wont it get in the way of the wheels getting in during mounting?
Old Mar 12, 2004 | 07:08 PM
benzz280's Avatar
benzz280
Michael.
Michael, are you refering to the brackets on the rear calipers which i am asking about? Are they needed for the swap?
2003z's Avatar
2003z
yes, the front rotors. you cant leave it in with stock wheels or take it out. wont make a difference.
Old Mar 12, 2004 | 07:09 PM
benzz280's Avatar
benzz280
i see, thanks 2003z
Old Mar 12, 2004 | 09:57 PM
zland's Avatar
zland
Sport Z Magazine
Has anyone purchased Track brembos from any Z owner or aftermarket that anyone knows of? I am wodring how much i could pick up a set for????
Old Mar 13, 2004 | 02:52 PM
Michael-Dallas
Correct, I am referring to the brackets. Whether you need them or not depends on if your brake lines has that junction block.
Michael.
Old Mar 15, 2004 | 08:57 AM
benzz280's Avatar
benzz280
i see, i am getting aftermarket lines, prob the stoptech lines and they dont have junction blocks, so does that mean i wont need the brackets and can disconnect them now? thx again Michael!
Old Mar 22, 2004 | 08:34 PM
benzz280's Avatar
benzz280
sorry for bringing this post up again, but for those who had done the swap, do i need to get new washers for the mounting bolts? or can i reuse the front ones since the front bolts are the same, but need to buy new washers for the rear ones?
Thx again!
Old Mar 22, 2004 | 09:09 PM
benzz280's Avatar
benzz280
any tips on what to use to clean the calipers and brake pads before the install??? i read about dust collector
thx again!
Old Mar 23, 2004 | 05:00 AM
daytona350z's Avatar
daytona350z
thx again!
well, when i put mine on, i disassembled the pads from the calipers. then i sprayed a 50:50 mix of simple green and water wiping the calipers with a cloth. cleaned em right up.
Old Mar 24, 2004 | 07:18 AM
benzz280's Avatar
benzz280
daytona350z, did you get new washers when you put them on?
Old Mar 24, 2004 | 01:56 PM
benzz280's Avatar
benzz280
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
nanotech
Oct 2, 2015 05:02 AM
Mikey R6
Sep 19, 2015 01:48 AM
