Will I be happy with drop of the Tein S. Techs?
Old Mar 19, 2004 | 09:56 AM
KraftG35's Avatar
KraftG35
Default Will I be happy with drop of the Tein S. Techs?
I've read all the posts regarding springs and the like but wanted to ask a more direct question as I"m sure there are others who are thinking the same thing.
I'm considering the Tein S. Techs for my G35C but I'm not sure if the advertised drop of 0.6/0.7 will be sufficient. I don't want to drop anymore than 1.0 inch because of the camber issues. I don't want to go with coilovers because of 1)cost and 2)i will never need to adjust the ride height as I won't track the car.
Is 0.6/0.7 enough to even notice the car has been dropped? Will I even notice a handling improvement?
Old Mar 19, 2004 | 10:21 AM
rogerudc's Avatar
rogerudc
I don't think its enough, visually. Go with the Eibach 1 inch drop all around. 1 Inch really isnt that much, and you see that once its installed. Handling is definitely improved either way.
Old Mar 19, 2004 | 10:47 AM
KraftG35's Avatar
KraftG35
I think I misquoted the drops. I believe it is -1.2/-0.9 front/rear. Sorry for the confusion.
Old Mar 19, 2004 | 10:51 AM
bobowah's Avatar
bobowah
if you don't want too much of a drop
get rsr down springs..
The tein's are nice but if you buy tein you should get their coilovers.
I have the eibach I like the ride very comfortable... but my car is really low... below the rsr downsprings.. I can't get the car on the lift with out using some blocks to raise the car.
-J
Old Mar 19, 2004 | 11:24 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I got a friend with G35c, he just installed Tein H.Tech, and he loves it! It does give it a subtle drop, and doesn't require camber kit, and it also improve the ride quality! Sounds like a win win situation!
Old Mar 19, 2004 | 03:14 PM
1nate7's Avatar
1nate7
Here are some pics of the H-Tech (G35) drop:
IMO its a noticable drop even with the H-Techs which is only a .6"/.3" drop. You will definetely notice the S-Tech drop and I personally wouldn't want any more of a drop than that.
Old Mar 20, 2004 | 08:27 AM
VQ35DES's Avatar
VQ35DES
Tien S is definately noticeable. Ive heard the spring rates on the Eibach were crappy, correct me if im wrong.
Old Mar 20, 2004 | 08:46 AM
GoSooners's Avatar
GoSooners
Now what you could do is get the TEin STechs for the 350Z for your G35 coupe. The STechs for the Z is a 0.7"/0.6" drop. Ride and performance will improve.
Old Mar 20, 2004 | 10:47 AM
Gsedan35's Avatar
Gsedan35
Whoa, everyone. G35 aftermarket spring rates are not the same as 350Z aftermarket spring rates. Things you've heard about a given Z specific spring on the Z won't translate the same experience for the G35 owner. Also consider that the G35 get's less aggresive shock valving to. One thing of note, I've spoken to a G35 coupe owner that is running RSR down springs ment for the 350Z on his coupe, he gave them a very good review.
Here's what I mean about aftermarket springs and rates for the Z and the G. Look closely, some G35 rates, are not sensicle in way's that go beyond trying to compinsate for softer shock valving.
Eibach spring rates
350Z 296/384 front 316/421 rear
G35C 229/337 front 274/463 rear
Tein S-tech
350Z 386/402
G35C 358/274
Tein H-tech
350Z 358/375
G35C 324/263
Old Mar 21, 2004 | 12:49 AM
joust75's Avatar
joust75
Default Re: Will I be happy with drop of the Tein S. Techs?
Check this thread
tein S tech on DB Z
I was wondering the same thing so I asked questions. You may judge for yourself regarding appearance by the above pictures.
As for performance... according to Bat the Tein S tech drop improves handling only marginally.
I am like you in that I dont want to go lower than 1" and I didnt want Eibachs because I hear they sag lower than 1 inch.
I decided on B+G springs. 1 inch drop all around, a good rep and only $150 on hopupracing.com
Cant wait!
Old Mar 21, 2004 | 03:52 AM
notlownf's Avatar
notlownf
I have the S-Techs on my coupe and I love them. Here are a couple crappy pics of my coupe after the drop.
Attached Thumbnails Will I be happy with drop of the Tein S. Techs?-2-28-04-front.jpg
Old Mar 21, 2004 | 03:58 AM
notlownf's Avatar
notlownf
All my other pics are too big to load, and I'm a little lazy this morning. PM me if you like and I can send you some better ones.
Attached Thumbnails Will I be happy with drop of the Tein S. Techs?-g35-and-xterra.jpg
Old Mar 21, 2004 | 10:22 AM
notlownf's Avatar
notlownf
Here's another one
Attached Thumbnails Will I be happy with drop of the Tein S. Techs?-overlook-park2-1.jpg
Old Mar 21, 2004 | 10:23 AM
notlownf's Avatar
notlownf
Wait! I found one more.
Attached Thumbnails Will I be happy with drop of the Tein S. Techs?-overlook-park3-1.jpg
Old Mar 21, 2004 | 01:40 PM
Reggi914's Avatar
Reggi914
I did a double take with those tracks rims on your G
Old Mar 21, 2004 | 02:01 PM
notlownf's Avatar
notlownf
I get that a lot
Old Mar 22, 2004 | 06:47 AM
KraftG35's Avatar
KraftG35
notlownf - just PMed you. Double take...I had to triple take that one. They look good on a coupe.
Old Mar 22, 2004 | 07:14 AM
notlownf's Avatar
notlownf
I sent you a bunch of emails with pics. I hope they help.
Thanks for the compliments on the wheels. I think they give the car a little more aggressive look.
Old Mar 22, 2004 | 09:04 AM
rogerudc's Avatar
rogerudc
Anyone have opinions on the H&R Springs? I have yet to hear these mentioned..
Old Mar 22, 2004 | 10:37 AM
KraftG35's Avatar
KraftG35
Default Re: Re: Will I be happy with drop of the Tein S. Techs?
Originally posted by joust75
Check this thread
tein S tech on DB Z
Cant wait!
Don't the B+G's drop 1.2/1.2?
