Any good shops in South Florida Suspension
Old Apr 9, 2004 | 05:31 PM
ga5252's Avatar
ga5252
Default Any good shops in South Florida Suspension
Any body know of a good suspension shop for Camber Adjustment in South Florida. I have the Eibach Springs with 19" Rims and desperatly need the camber adjustment before I waste my tires.
Old Apr 9, 2004 | 05:40 PM
westpak's Avatar
westpak
SFZCC
Well I assume that you either have a camber kit or are only talking about the rear tires?
Old Apr 9, 2004 | 07:37 PM
ss350's Avatar
ss350
"Miami Chassis". They do great work!
Old Apr 10, 2004 | 08:30 AM
ga5252's Avatar
ga5252
I think I just need the rear tires. What would be best?
Old Apr 10, 2004 | 08:51 AM
westpak's Avatar
westpak
SFZCC
Well you should get a 4 wheel alignment after a few weeks of the Eibachs being on, so they can adjust all settings. They cannot adjust the front camber but mine just happened to be at the limit but they should check and adjust the toe on the front and the camber and toe on the rear, they were able to adjust the camber to within limits and the toe is just barely out, so far almost a year later no visible effects. You don't need to take it anywhere special I had mine done at the dealer.
Old Apr 10, 2004 | 08:57 AM
ga5252's Avatar
ga5252
What dealer did you take it to? How much did they charge you?
Old Apr 10, 2004 | 09:45 AM
westpak's Avatar
westpak
SFZCC
Well, I am up in Palm Beach, took it to Palm Nissan and I think it was 90.00.
Old Apr 11, 2004 | 03:56 PM
Jun's Avatar
Jun
By adjusting your camber, what do you mean? like bending the camber arms? because i wouldn't recommend that. Just buy some adjustable camber arms from lsdunique and get them installed like at TK performance or something, that's what Slaponte did, and it looks like they did a good job. If you want to actually bend your arms, then i think you can take them to Miami Chassis and they'll do that for you, but by doing that you are weakening them...
Old Apr 11, 2004 | 05:24 PM
westpak's Avatar
westpak
SFZCC
The rear camber is adjustable, not a lot but some, in my case they were able to adjust to within limits no bending.
Old Apr 13, 2004 | 04:56 AM
ga5252's Avatar
ga5252
What brands of camber kits are out there that I can use and that are good?
Thanks for all your help guys! Its really appreciated.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
