Strutbar question?
Old Apr 20, 2004 | 01:36 PM
alphared's Avatar
alphared
Question Strutbar question?
I removed the strut bar (to install plenum) and then reinstalled it by loosening the nuts so that the blots line up. Then re-tighten it. I think I over-tighten it, but not sure. The strut seems to have various bows in it. Did I break it or is this natural? I didn't hear anything crack or see any (just a slight tighten noise from the strut pushing against the bolts.
Old Apr 21, 2004 | 02:22 PM
zwindsor's Avatar
zwindsor
Twisty addict
There shouldn't be multiple bows/bends in it.
Once you've tightened the nuts by the struts you are only supposed to turn the main center nut 1.7 turns, rotation is towards the front (counterclockwise looking at it from the driver side). The gap between the bar and the engine cover should be between 10-17mm.
Old Apr 22, 2004 | 03:04 PM
alphared's Avatar
alphared
So is the strut straight? Looking at it, there a slight M look, where the middle dips.
Hard to tell if I overtighten it and bent it because the paint hasn't chipped and still looks like a solid one piece.
Old Apr 22, 2004 | 03:32 PM
zwindsor's Avatar
zwindsor
Twisty addict
Yea, it has a slight M shape to it. You're OK but suggest you untighten it and redo it following the steps I gave you.
Old Apr 22, 2004 | 04:51 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
it takes over 800lbs of pressure from side to side pushing into the stock stb...
dont think you could have bent it...
it should have a few bends in it...
here is a pic of mine...
Old Apr 22, 2004 | 07:43 PM
alphared's Avatar
alphared
*whew*
Thanks guys, good to know I didn't bend it.
Ah, All is good and I can drive fast again
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
