Alignment numbers after springs install..not good
Old Dec 9, 2004 | 02:59 PM
  #41
slaponte's Avatar
slaponte
Hey but thanks for the info and specs. I like Kinetix stuff and if I am not convinced on the cam bolts I might just get the traction arms from them. Thanks.
Old Dec 25, 2004 | 11:43 AM
  #42
tonio's Avatar
tonio
I'm just wondering if you guys are installing the camber rods yourself? If so is there a DIY somewhere?
Old Jan 3, 2005 | 09:08 AM
  #43
slaponte's Avatar
slaponte
I had the camber arms installed at the shop because they did an alignment right after, so what the heck. But they aren't too hard, they have 1 bolt on each end, end of story.
As chilton would write it :
A) Remove existing bolts
B) Remove existing arm
C) Install is reverse of removal...
Old Jan 3, 2005 | 07:05 PM
  #44
maximumsportZ's Avatar
maximumsportZ
Did your shop have to take off your wheels to install them?
Old Jan 4, 2005 | 04:53 AM
  #45
kinjal's Avatar
kinjal
wouldnt the tein S TECH springs not cause any camber issues? it gives you a decent drop, and stays below the .8" drop that will cause the camber issues.
TEIN S-TECH SPRINGS
Spring rate: Front 386lbs Rear 402lbs
Lowers: Front -0.7" Rear -0.6"
Old Jan 4, 2005 | 07:50 AM
  #46
slaponte's Avatar
slaponte
For the rears, no, you shouldn't have to. But they did because I was having the tires rotated, etc anyway. You can reach it from behind/below the car, but could be more cumbersome than necessary.
For the fronts, most definetly. Tires, struts had to be loosened, strut bar, etc just to get to those two bolts...
Old Jan 16, 2005 | 10:50 PM
  #47
ReavTek's Avatar
ReavTek
Sorry for sounding a little ignorant but what is a cam bolt? Where do I buy and and what does it do exactly?
Old Jan 18, 2005 | 07:18 AM
  #48
slaponte's Avatar
slaponte
You have one now.
The rear toe adjustment on the car is a bolt with a washer that is "offset": it is wider on one side than the other. As you turn it, that offset pushes the arm in or out, by a few milimiters.
A larger cam bolt will have a larger offset, thus allowing more adjustment. The ones I got have a -3 to +3 adjustment.
I got mine from here :
Import Auto Parts Direct
Note that they sell a kit with camber and toe. If you email them they sell you the Toe bolts alone.
The larger Toe bolts do require that you enlarge the hole on the arm where they go. Instructions and template are included with the bolts.
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
