Minor Sound coming from Tein Coilover
Old May 7, 2004 | 09:08 AM
NismoGCoupe's Avatar
NismoGCoupe
Default Minor Sound coming from Tein Coilover
Just wanted to know if a clinging sound is normal with the Tein CS it seems every once in a while if i cut the wheel to the left or right I get a minor clinging noise, does this mean they weren't installed correctly or is this normal? its very minor sound and it happens ocassionaly
Old May 7, 2004 | 09:11 AM
Trent@MVP's Avatar
Trent@MVP
Tein's on most cars are known to be a little "noisy". Some cars it is more prevalent or obvious than others, but a lot of Tein kits I've installed and driven have had some small squeaks and noises. Just to be on the safe side I would go over it and make sure everything is snug and tight though.
Old May 7, 2004 | 09:21 AM
NismoGCoupe
well it not noisy at all when im driving if im at a standstill and I turn the wheel all the way once in a while it will make a cling noise
Old May 7, 2004 | 10:48 AM
Road Warrior's Avatar
Road Warrior
did you have the car aligned? if so, make sure they tightened everything!
Old May 7, 2004 | 10:49 AM
NismoGCoupe
no i havent had it aligned
Old May 7, 2004 | 03:27 PM
Road Warrior
interesting, i had a set with the same problem and mechanics forgot to tighten everything during alignment. must be the upper ball joint...try lubing that and see if that eliminates the problem. as was said earlier this is probably normal unless there is something loose...you might want to consider getting an alignment too
Road Warrior
dp...dammit
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
