analyzing my alignment results...
Old Jun 17, 2004 | 04:04 PM
krazE's Avatar
krazE
Default analyzing my alignment results...
How bad?
Final readings:
left front: right front:
caster +8.88 +9.04
camber -1.40 -1.80
toe +1/16 +1/16
left rear: right rear:
camber -2.44 -2.28
toe +1/16 +1/16
total toe:
front +1/8
rear +1/18
Old Jun 18, 2004 | 01:27 PM
Gsedan35's Avatar
Gsedan35
You went to toe out?
Old Jun 18, 2004 | 01:37 PM
krazE's Avatar
krazE
well, it was aligned before - but i put new springs in... so the dood suggested that
Old Jun 20, 2004 | 06:30 PM
myz8a4re's Avatar
myz8a4re
you need toe in to keep from feathering(supossedly). you need a total toe in of .08(in) or .2*in the front....your camber is pretty heavy too, probably handles nice but will eat up your inner tire edges pretty quik, unless you requested that purposely for track duty...........
-justin
Old Jun 20, 2004 | 07:49 PM
krazE's Avatar
krazE
camber is bad in front and rear? don't want to buy new $1,000 tires again
Old Jun 21, 2004 | 08:54 AM
myz8a4re's Avatar
myz8a4re
yes, your camberis a tad heavy on the negative side. fronts arent too bad but herears are over 2* neg. this will eat your inner tires fast. since you lowered it you might need rear camber arms to get it back in spec thats what i did. i even run less aggressive camber than factory to save my $1000 tires.........
-justin
Old Jun 21, 2004 | 09:40 AM
Road Warrior's Avatar
Road Warrior
if you lower any more than .8 inches you will have camber problems. its a matter of how much its off and how much you want to spend to correct the problem. front camber components are not cheap.....and neither are your tires
Old Jun 21, 2004 | 02:30 PM
myz8a4re's Avatar
myz8a4re
heck, none of the front or rear components were cheap but together they were less than a new set of tires! i look at it like this: suspension parts purchased once for full life of tires or unevenly wear your expensive tires & replace frequently forever!
depends on your wallet i guess.........
-justin
Old Jun 21, 2004 | 09:20 PM
krazE's Avatar
krazE
wow, so kinetix has front arms too
Old Jun 21, 2004 | 09:39 PM
AmyCroft's Avatar
AmyCroft
Default Re: analyzing my alignment results...
Originally posted by krazE
How bad?
Final readings:
caster +8.88 +9.04
camber -1.40 -1.80
toe +1/16 +1/16
camber -2.44 -2.28
toe +1/16 +1/16
total toe:
front +1/8
rear +1/18
How about this?
caster +10 +10
camber -1.40 -1.40
toe +1/32 +1/32
camber -2.00 -2.00
toe +1/32 +1/32
total toe:
front +1/16
rear +1/16
The car has Hotchkis Springs Sways
And Hotchkis ProtoType Camber rods..
Manual alignment.. 5000 miles on new NNA provided tires.. Some
Front feathering - outside when at 1/8th total... Inside at 1/16 total...last 3000 miles...
Old Jun 22, 2004 | 09:50 AM
myz8a4re's Avatar
myz8a4re
makes ya crazy doesnt it?
-justin
user 62082028
Southern California
Jul 28, 2017 11:47 AM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
