Pics of Silver Stoptech Brake Kit
Old Jun 21, 2004 | 01:06 PM
stx's Avatar
stx
Default Pics of Silver Stoptech Brake Kit
I wanted to share some pics of my silver 13" Stoptech brake kit.
Old Jun 21, 2004 | 01:07 PM
stx's Avatar
stx
Another
Old Jun 21, 2004 | 01:08 PM
stx's Avatar
stx
Last one
Old Jun 21, 2004 | 01:15 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Very nice, just the front right? how much? where did you get them from?
Old Jun 21, 2004 | 01:22 PM
stx's Avatar
stx
It is just the front. I bought them from Performance Nissan and if I remember right I paid around $1800.
Old Jun 21, 2004 | 01:26 PM
HaNkYs_Z's Avatar
HaNkYs_Z
did you install them or you get someone to install for you? how hard is the install? or how much did you pay to get install?
Old Jun 21, 2004 | 01:42 PM
stx's Avatar
stx
I did the install myself. I did not find it difficult at all. I would say if you have every replaced your brake pads or replaced your brake rotors this kit would be a DIY job. It took me about an hour to due both sides. The hardest part is breaking the 22mm caliper bolts. Once you get that done and remove the caliper the rotor will slide out and and the rest is cake.
Old Jun 21, 2004 | 01:54 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Did you replace your rear rotors or brake lines too or the rears are completely stock?
Old Jun 21, 2004 | 02:04 PM
stx's Avatar
stx
I just replaced the rear brake lines with the Stoptech SS lines only. I already had the SS brake line before the kit.
Old Jun 21, 2004 | 06:21 PM
Zster's Avatar
Zster
i am sorry i didnt understand what you mean by breaking the 22mm bolt... do u think the g35 brembos will bolt right on to the Z's regular brakes... any info is much appreciated....ty
Old Jun 21, 2004 | 08:56 PM
Joe999's Avatar
Joe999
Their nice, but I think you should have gotten red ones. Red on red looks awesome--very ferrari-ish. The silver ones would look perfect on CS, though. Just my opinion of course.
Old Jun 21, 2004 | 09:20 PM
THX723's Avatar
THX723
He meant it took some effort to get the two 22mm bolts holding down the calipers off. A large breaker bar is definitely a plus for this job. The G35 Brembos are identical to the Z brembos. They will bolt onto your presumably non-brembo Z without any hitch.
Nice pics btw ... STX I've got silver ones on their way. This is the first time I've seen 'silver' in pics ... thanks buddy.
Old Jun 21, 2004 | 09:37 PM
Zster's Avatar
Zster
thanks THX ... i amma swap my stock G35 brembos to my Z
Old Jun 21, 2004 | 09:43 PM
THX723's Avatar
THX723
Good deal. The oem Brembos are very sexy in my opionion. I love the gold calipers.
Old Jun 22, 2004 | 05:13 AM
stx's Avatar
stx
Only reason I didn't get red was because I didn't get a four wheel kit. I thought it would look funny with red caliper in front and a stock gray caliper in back.
They should bolt right in if you use the rotors also.
Thanks... I hadn't seen very many pics of the silver either.
Old Jun 22, 2004 | 01:43 PM
Zster's Avatar
Zster
did you have to cut the metal plate behing the stock brake rotors.... to fit the stoptech big brake system... how about the brake lines... do i also use the ones from the g35 also.... i amma do it this thursday... thanks for the info
Old Jun 22, 2004 | 02:15 PM
stx's Avatar
stx
Yeah you have to cut the dust plate to get the rotor on. The plate is thin so its really easy to cut.
I did have to change my brake lines since the rotors were bigger. You might not though if the stock rotor is not that much bigger. When you put on the brembo rotors and caliper turn you wheel fully right and left to see if the brake lines are clear and don't have alot of tension. If not changing them out using a flare wrench and needle nose pliers to remove the clip. Try to use a rubber mallet to put the clip back in. It makes it easier.
Old Jun 22, 2004 | 09:13 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
was bleeding the brakes relatively easy?
Old Jun 22, 2004 | 10:15 PM
THX723's Avatar
THX723
Easier than you'd imagine GQ. Although ... it's best performed with two person working in tendon, unless you have speed bleeders or better yet a Vacuum bleeder.
Old Jun 22, 2004 | 11:20 PM
Zster's Avatar
Zster
thanks stx good info... i amma post some pics with it on afterwards...
