What brake pads you use to reduce squealing
Old Jul 21, 2004 | 06:21 PM
Chicken's Avatar
Chicken
This is so whacked. I could swear that there were many, many posts about EBC and how horrible they were, no one recommending them, etc.
Old Sep 2, 2007 | 03:41 PM
DanielW's Avatar
DanielW
Is your squealing happening at low speeds under light pressure only? this is what i'm getting and no one can seem to figure it out
Old Sep 2, 2007 | 04:33 PM
DavesZ#3's Avatar
DavesZ#3
^^^^ Dude, the thread is 3 years old.
Old Sep 2, 2007 | 07:09 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I know the thread is old, but the nature of the Brembo caliper is the most cause of the noise in all honesty. There are some compounds out there which minimize the noise, but not all of them can eliminate it. I know Endless has a pad coming out soon that was made specifically for this brembo caliper design, as it's used on many different cars (not the exact pad, but from the same family)
Old Sep 2, 2007 | 07:18 PM
DavesZ#3's Avatar
DavesZ#3
danielwebb drives an Enthusiast, not a Track/GT so Brembos aren't the problem.
Old Sep 2, 2007 | 07:27 PM
Z1 Performance
Former Sponsor
ah ic...well then, scratch that
Old Sep 4, 2007 | 12:41 PM
Q45tech's Avatar
Q45tech
Squeeling [acoustic vibration] is a function of the pads and rotors. Changing either leaves you with an untuned system + oem noise shims are tuned for oem pads so they don't usually work with non oem pads or rotors.
"Most brake squeal is produced by vibration (resonance instability) of the brake components, especially the pads and discs (known as “force-coupled excitation”.) This type of squeal should not negatively affect brake stopping performance. Simple techniques like adding chamfers to linings, greasing or gluing the contact between caliper and the pads (finger to backplate, piston to backplate), bonding insulators (damping material) to pad backplate, inclusion of a brake shim between the brake pad and back plate etc, may help to reduce squeal. Cold weather combined with high early morning humidity (dew) often makes brake-squeal worse, although the squeal stops when the lining reaches regular operating temperatures. However, some lining wear indicators are also designed to squeal when the lining is due for replacement. Overall brake squeal can be annoying to the vehicle passengers, passerby, pedestrians, etc especially as vehicles are designed to be more comfortable and quieter. Hence vehicle NVH (Noise, Vibration and Harshness) is one of the important priorities for today's vehicle manufacturers."
http://www.vibrationdata.com/Newslet...ust2006_NL.pdf
If you measure [record] the acoustic signal and then use a spectrum analyser to define the squeel frequencies and amplitudes you can use advanced math to help reduce the problem.................just what Nissan does with every car design!
http://www.dyn.tu-darmstadt.de/pub/b...xperiments.pdf
Different Control Strategies for the Active Suppression of Brake Squeal
Book Series Solid Mechanics and Its Applications
ISSN 0925-0042
Volume Volume 130
Book IUTAM Symposium on Vibration Control of Nonlinear Mechanisms and Structures
Publisher Springer Netherlands
DOI 10.1007/1-4020-4161-6
Copyright 2005
ISBN 978-1-4020-4160-0 (Print) 978-1-4020-4161-7 (Online)
DOI 10.1007/1-4020-4161-6_14
Pages 161-171
Subject Collection Engineering
SpringerLink Date Saturday, January 28, 2006
When owners go redesigning systems they must be prepared to do the science to correct problems they create!
Old Sep 4, 2007 | 05:23 PM
DanielW's Avatar
DanielW
my "system" is OEM though
Old Sep 5, 2007 | 06:00 AM
zzz350's Avatar
zzz350
I have been using Hawks for 2 years and literally have zero noise (bedded them incorrectly when first put on the car and they squeeled, rebedded them and found perfection). Literally no dust and no noise, I would highly recommend Hawks.
samansharif
Sep 25, 2015 12:31 PM
