Possible Hotchkis Sway Bar fix
Old Jan 9, 2006 | 06:59 PM
  #61
03Z33's Avatar
03Z33
No need for alignment if all your changing is sways.
Old Jan 9, 2006 | 08:07 PM
  #62
Triple8Sol's Avatar
Triple8Sol
For anybody that thinks the McMasters collars are unnecessary..THINK AGAIN. I had installed my Hotchkis sways and ran on them for a month or two. Besides daily driving, I AutoX'ed it a couple times. When I finally got around to putting the collars in, I actually had to loosen up the mounting bolts to readjust the front bar, just to get the collars on...
Old Jan 10, 2006 | 07:37 AM
  #63
zwindsor's Avatar
zwindsor
Twisty addict
Originally Posted by blackznismo
do you have to get alignment done after you install the hotchkis kit with the collars...i know if you work on your suspension in any form that re-alignment is needed....so is re-alignment neccessary?
No. Sway bars don't affect alignment. Just bolt them in.
Old Jan 10, 2006 | 10:50 AM
  #64
blackznismo's Avatar
blackznismo
thanx
Old Jan 16, 2006 | 02:09 PM
  #65
blackznismo
JUST had them in yesterday with collars...med/med...my god what a difference. Freakin bolts...it was crazy to get them off....I ended up buying impact wrench...
Old Jan 21, 2006 | 02:33 PM
  #66
nbdyfcnsqnc's Avatar
nbdyfcnsqnc
Aha, I think I'm going to have to get these collars too... Thanks for the info Zillinois.
Old Jan 21, 2006 | 03:25 PM
  #67
zYouLater's Avatar
zYouLater
Use a marine grease. I have used this on my Hotchkis and it does not come off, It is used to lubricate boat props and will stand the test of time agains the eliments. Any auto supply should have it as well as Marine Stores.
Good luck
Old Apr 11, 2006 | 10:42 PM
  #68
bacalhau16's Avatar
bacalhau16
does anyone think that these collars are actually having a bigger effect on the swaybar then just not making it move. if ur putting the collar on the bar, its kinda like having two seperate bars. its really tightening up the bar, and not using the whole bar. Hence making an already stiff swaybar, that much stiffer? Am i over thinking here?
Old Apr 12, 2006 | 02:57 AM
  #69
zillinois's Avatar
zillinois
The collar just clamps on to the bar, it does not "tighten" it up by clamping hard against the bushings. If you took off the endlinks, you could rotate the bar with the same amount of force with the collars on or off. The amount of lateral force on the sway bar is relatively small. So even if the collar pushes against the bushing in a corner the amount of rotational resistance it would add is negligible. It would almost certainly add less rotational resistance than having the sway bar slammed all the way to one side.
Old Apr 12, 2006 | 05:00 PM
  #70
bacalhau16's Avatar
bacalhau16
Makes sense well put. Sorry that was kinda like one of those questions where you couldnt figure out the answer till you walked up to the teacher.
Old May 6, 2006 | 04:48 AM
  #71
MrKaira's Avatar
MrKaira
Really MrZ31
Are those collars unique to mcmasters? They are a long way from here, and i'd rather not wait on shipping.
basically where else might I be able to find collars so I don't have to wait on shipping?
Old May 6, 2006 | 05:39 AM
  #72
zillinois's Avatar
zillinois
You might be able to find them at a hardware store, but I doubt it. Mcmaster has distribution facilities on the East Coast. So I doubt you'd have to wait more than a day for them.
On another note, this thread is probably moot now that Hotchkis decided to include collars with their new bars.
Old May 6, 2006 | 05:48 AM
  #73
techcontrol's Avatar
techcontrol
When did Hotchkis start including them? I installed the TVS in March and no collars were included. I need to call the vendor I bought the kit through and see if they will "grandfather clause" the collars.
Old May 6, 2006 | 06:50 AM
  #74
MrKaira's Avatar
MrKaira
Really MrZ31
really? i need to go check the box then because i just got the sways in a couple days ago...
Old May 6, 2006 | 06:52 AM
  #75
MrKaira's Avatar
MrKaira
Really MrZ31
ok i'm going to sound like a dumbass, but are the bushings the same thing as the collars? cause i got bushings and 2 brackets... but no "collars"
Old May 6, 2006 | 07:58 AM
  #76
techcontrol
Nope, the bushings are not the collars. The poly bushings replace the stockers but utilize the OEM swaybar brackets. Make sure you use the grease (included in the kit) on the inside of the bushings and wear gloves while handling the grease/bushings, it's really tough to wash off your hands.
Old May 6, 2006 | 08:24 AM
  #77
zillinois's Avatar
zillinois
https://my350z.com/forum/brakes-and-suspension/188838-hotchkis-sway-bar-improvements.html
Old May 6, 2006 | 09:00 AM
  #78
MoodDude's Avatar
MoodDude
Zillinois - Thanks for your help! I have had the collars on for a few months now and they work perfect! And you are right - my front had moved over 3 inches or so and it on mine, it seemed to be binding.
If you ever do a track event in the South, let me know as I will probably be there too.
Old May 7, 2006 | 08:19 AM
  #79
jovasi's Avatar
jovasi
There are only collars on the front bars now, not the rears.
Old May 8, 2006 | 08:47 PM
  #80
GreekZ33's Avatar
GreekZ33
that sucks... i waited all this time and just got my TVS a month ago.. and NOW they decide to put the collars on.. oh well. i'm still more than happy with my TVS kit
