Eibach springs for the Z
Old Oct 20, 2004 | 10:25 AM
tonester1011's Avatar
tonester1011
CF God
Default Eibach springs for the Z
I just put the Eibach Pro kit on my car and i need to have it realigned. Does anyone know the specs to realign the Z with these springs on it so i can give it to the guys to put it in their allignment machine.
Old Oct 20, 2004 | 04:35 PM
Reaper700's Avatar
Reaper700
Here is link to the spec courtesy of Peformance Nissan
http://members.aol.com/performancenismo/algn.jpg
Old Oct 20, 2004 | 06:45 PM
zwindsor's Avatar
zwindsor
Twisty addict
PM me your email addy and I'll send you Nissan's spec sheets. These are for 18" wheels.
Old Oct 21, 2004 | 09:17 AM
tonester1011
CF God
Im going to put my stock 17's back on to have it alligned. Will it be the same for 17's as 18's. Im not to familiar with all this stuff.
Old Oct 21, 2004 | 09:29 AM
zwindsor's Avatar
zwindsor
Twisty addict
The toe specs for the rear are different for 17's & 18's. Why would you put the 17's back on? You afraid they will damage the 19's?
Old Oct 21, 2004 | 01:40 PM
tonester1011
CF God
No, the guy that does my allignment and stuff has a machine but it will not fit 19's on it. The biggest the machine can do is 18's. Plus winter is coming and im going to put the stock rims on for the winter anyways. Im in jersey and anyone here knows that winter can be kinda tough on rims sometimes.
Old Oct 21, 2004 | 02:19 PM
zwindsor's Avatar
zwindsor
Twisty addict
Alot of the places around here can't even do 18's let alone 19's. I'm originally from Jersey so I know about the lovely winters.
You should still let me send you the proper specs.
Old Oct 21, 2004 | 05:44 PM
sponsorsthisway's Avatar
sponsorsthisway
Do you need to buy the camber kit if you have 19's when u drop it with the eibachs???
Old Oct 21, 2004 | 05:56 PM
Hamy's Avatar
Hamy
So if your lowered on 19s w/ Eibachs you don't align it to stock specs? Why? Should I use the ones posted above? Do I need a camber kit in the rear?
Old Oct 22, 2004 | 10:57 AM
zwindsor's Avatar
zwindsor
Twisty addict
Camber kits aren't mandatory. It all depends on the individual car. Some have needed it some haven't. Get an alignment and find out. If they can't get within specs then get a kit.
Old Oct 22, 2004 | 12:41 PM
dnguyent's Avatar
dnguyent
Why would alignment specs be different for different sized rims? It doesn't make any sense. Before I go in for my alignment, I will take off my 19's and slap on my OEM 17's. It's shouldn't make a single difference unless you have a very different offset between the two sets of wheels, as it affects camber.
Old Oct 22, 2004 | 02:39 PM
tonester1011
CF God
zwindsor i sent u a pm
Old Oct 22, 2004 | 04:07 PM
zwindsor's Avatar
zwindsor
Twisty addict
The offsets may be different ....never paid any attention. According to the specs it's only the rear toe that is different...quite a bit too.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
