JDM Skyline Brakes?
I am about to get a set of JDM brakes from a Skyline, I beleive R34. Does anyone know anything about these brakes, I was told they are better than Brembos? Direct bolt on to a G35?
Originally posted by Mike Wazowski
They use the same caliper as the U.S. Track model 350Z.
I was told they are black with red NISSAN letters.
so its possible to fit the skyline calipers onto a z33? i have base,. a long time ago i won a pair for 300zx aluminum front calipers (same as skylines) on ebay but i didnt pay for them because after i won it i was convinced that it will fit but it will be an unreliable conversion. am i wrong?
Originally posted by John
They're very similar, but share a 5mm difference offset, both in the rotor and caliper bracket.
Originally posted by ihatethatbobbarker
whoah whoah whoah
if they say nissan on them they arent from a gtr, and arent brembos, they are probably worse then what you have.
i think they bolt on though.
whoah whoah whoah
The z32 calipers are 4 piston calipers. we put them on the Z31s also. the z31 turbos have what looks to be the same brake caliper as my touring 350z. twin piston caliper. so woulden't the z32 4 piston caliper be better than the reg twin piston?
this could possibly be another brake up grade option. If u match a good pad and rotor to it.
G
G
I would not even bother using those brakes if they are the ones labelled "Nissan". While they are a 4 piston (Subaru's in Japan use a nearly identical caliper), the actual size of the pad theta is used is not much bigger than the OEM Z pad - I fail to see what benefit it will offer other than slightly improved intial feel.
All the while I thought you got Skyline Brembo's and were asking if they fit...sorry
