whats the trick to getting front strut out?
Old Nov 19, 2004 | 11:24 AM
del105's Avatar
del105
15 f125
Default whats the trick to getting front strut out?
So I'm replacing struts but I cant seem to get it out. I pull down on the upper A-arm to try to pull the bottom of the strut free but am having no luck. I've also unhooked the fsb as well.
Old Nov 19, 2004 | 11:45 AM
jester7500's Avatar
jester7500
Use the jack that came with the car and put it between the upper a-arm and the inner fender. Be careful and make sure its stable. This will give you enough clearance to get the whole strut assembly out without spring compressors. Hope this helps.
Old Nov 19, 2004 | 11:51 AM
John's Avatar
John
Unbolt the ball joint on the UCA.
Old Nov 19, 2004 | 12:14 PM
del105's Avatar
del105
15 f125
John, that worked. thanks!!
I was a little hesitant to try the jacking method conserned about bending something.
Old Nov 19, 2004 | 12:47 PM
John's Avatar
John
No problem.
Old Nov 19, 2004 | 05:45 PM
scubasteve's Avatar
scubasteve
I remember those damn struts!!!! For me, it just took a lot of wiggling and four letter words.
Old Nov 20, 2004 | 11:52 AM
arizzee's Avatar
arizzee
A little late but ... when putting on my Konis, I just unbolted the stabilizer bar endlink, loosened (but don't remove) the shock tower nuts, then have your buddy push down on the hub/rotor assy. I didn't have to remove the nut from the UCA ball joint.
Old Nov 20, 2004 | 12:56 PM
havabooz's Avatar
havabooz
are you willing to sell your oem struts?...or any other component from front suspension
let me know
PM me
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
