Buying/Leasing 350Z/370Z Purchasing Info
Vehicle Dynamic Control?
Old Feb 26, 2009 | 04:11 PM
SkyBox's Avatar
SkyBox
Default Vehicle Dynamic Control?
I am researching different 350's and trying to determine which model is best for me.
I cannot find much info on VDC and am wondering how helpful it is in slippery/gravely conditions.
It this feature helpful? From what I have read, it justs maintains the spin rate of the rear tires so they do not exceed the speed of the front, right?
Likes/dis-likes or additional info??
Old Feb 26, 2009 | 04:14 PM
2007 Z's Avatar
2007 Z
Every little bit helps when you need it. When you don't you turn it off.
I would personally be more concerned about the other options that come with the Touring+ that you are going to lose with a lower trim.
Old Feb 26, 2009 | 04:48 PM
DavesZ#3's Avatar
DavesZ#3
Search this forum for VDC and I'm sure you'll get hundreds of hits on the subject.
The short version -
VDC attempts to keep the car from spinning out. Yes, it is designed to be helpful in wet, slippery conditions.
TCS attempts to keep the rear wheels from spinning, normally under acceleration.
Old Feb 26, 2009 | 04:55 PM
JAbraham03's Avatar
JAbraham03
According to the manual, I think VDC also helps limit the torque of the car so you can not get to max HP. At least mine says to turn it off if you want to achieve max HP. Guess it helps you not mess up your engine as easily. It will actually act as a governor on your RPM. (maybe I read into it too much but it seems as though it works that way.)
Old Feb 26, 2009 | 05:09 PM
Old Feb 28, 2009 | 03:05 PM
bailey bill's Avatar
bailey bill
Originally Posted by JAbraham03
According to the manual, 1) I think VDC also helps limit the torque of the car so you can not get to max HP. At least mine says to turn it off if you want to achieve max HP. Guess it helps you not mess up your engine as easily. 2) It will actually act as a governor on your RPM. (maybe I read into it too much but it seems as though it works that way.)
1) Only when the car is on the verge of becoming unstable.
2) No, it won't.
bill
Old Mar 1, 2009 | 08:17 AM
dhays's Avatar
dhays
I have a GT and the VDC is fine. Frankly, since I tend to drive carefully, it never really engages, but I suppose it is a nice insurance against me being stupid sometime on a wet road.
I do autocross the car (not well). A couple times I have forgotten to turn the VDC off. I did this last weekend on a course that was very wet and slippery. There was one 180 degree apex where the second half of the turn was a LOT more slippery than the first half. I kept having problems as I was coming out of the turn putting too much power on and would lose the back end. When I forgot to turn the VDC off, this wasn't a problem and the VDC was able to hold the power just at the point necessary to keep the back end where it should be. It is really a strange feeling to be racing through autocross elements and pushing the petal down and yet have the car hold just enough power to stay tame. From these experiences, I think the VDC does work well. HOWEVER, it won't save a driver from their own stupidity.
If you get the car, I suggest trying autocross. It is fun and will make you a better and safer driver.
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
