Buying/Leasing 350Z/370Z Purchasing Info
Is there something wrong with this Z?
Old Apr 23, 2009 | 06:15 PM
meth98's Avatar
meth98
Default Is there something wrong with this Z?
I ran a carfax and it says that it was involved in a minor accident but it gave the carfax buy back guarantee. it doesn't look like the front bumper lines up correctly. anyone agree or have any insight with it? only silverstone i've found in the area.
Old Apr 23, 2009 | 06:37 PM
xsupan0va's Avatar
xsupan0va
not sure about the carfax buyback because i use autocheck
Check the fine print. You should always inspect the car with a 3rd party mechanic/shop because if there was an accident and it wasn't reported, then it would not be listed on the carfax.
and you may be right. It seems uneven.
Old Apr 23, 2009 | 07:04 PM
R350Zz33's Avatar
R350Zz33
looks like the hood and bumper spacing is off and the side skirts arent stock
Old Apr 23, 2009 | 07:44 PM
avandss's Avatar
avandss
jobber bumper maybe?
Old Apr 23, 2009 | 07:47 PM
03aeroZ's Avatar
03aeroZ
after market front strut bar? that may be hitting the hood? The whole front end looks off actually....all the way around the lights, the hood, everything.....do not buy. Or, if you do, prepare to get some body work done.
Old Apr 23, 2009 | 07:54 PM
THE_SCHROED's Avatar
THE_SCHROED
Lights are painted and calipers are painted. Watch out the car has probably been ragged out, it probably had an aftermarket kit and rims on it.
Old Apr 23, 2009 | 08:00 PM
03aeroZ's Avatar
03aeroZ
Those do look like the ebay "blacked out" lights....good call.
Old Apr 23, 2009 | 09:00 PM
kyx4n's Avatar
kyx4n
yup, looks like the previous owner had some exterior changes, and changed it back to stock before selling
Old Apr 24, 2009 | 02:15 AM
Ziggyrama's Avatar
Ziggyrama
If you see that car again, pop the hood and look at the hood latch. There's some wiggle room on it which may explain the hood being slightly off. When I replaced my radiator bracket, I had to pull mine off and after reassembling, my hood was doing the very similar thing to what you see on the pictures above. It takes 5 minutes to fix that with a ratchet and a 10mm socket. Just loosen the bolts, adjust the latch by pushing it down slightly, tighten the bolts and see if the hood lines up better. That's all it takes most likely.
If you're seriously considering the car, put on a lift and have a mechanic look it over. My guess is the car was in a front crash which probably explains the front looking off because parts were taken out and replaced.
Old Apr 24, 2009 | 03:47 AM
meth98's Avatar
meth98
the carfax did state it was in a front end accident. it's a touring model but the rims don't match up either. i haven't seen it in person but am going to look at it today.
Old Apr 24, 2009 | 07:18 AM
lgear080's Avatar
lgear080
NEXt. that car is a turd. **** carfax - completely unreliable. don't waste your time!
there are soooooooo many better, perfect cars, that this need not absorb your effort.
Old Apr 24, 2009 | 09:03 AM
meth98's Avatar
meth98
i'm not buying it unless they come down to 10k or less. the search continues.
Old Apr 24, 2009 | 09:10 PM
Hood-front bumper fit is poor.
Old Apr 24, 2009 | 09:13 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
LOL at "Golden Oldies" car sales.
Obadabot
Jun 18, 2023 11:31 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
