Buying/Leasing 350Z/370Z Purchasing Info
Torn between an 03 350z and a couple non-350z cars
Old Feb 9, 2014 | 06:42 AM
  #61
TuckerE36's Avatar
TuckerE36
OP congrats on deciding on the Z after much debate! Now your first change to that Z should be to ditch the blue interior LED's and change them to white, I feel it will make your interior "Pop" so to speak. Then for the love of man get rid of those nasty blue HID's. If you can swing it look for a good used set of 06+ headlights. If those are too expensive then swap the bulbs to no more than 6k TOPS!!! Light output should be more important than color. Safety first!
Old Feb 9, 2014 | 06:49 AM
  #62
Jah70's Avatar
Jah70
And put some gas in that thing. I get a panic attack every time I see a gas gauge go below half. Also that intake is rubbish and probably not much better maybe worse than stock. You need one that extends down into the bumper right behind the yellow side marker to breath in the nice cold filthy cancerous air. You'll have to remove the side markers and replace them with some type of mesh though.
Old Feb 9, 2014 | 08:44 AM
  #63
Whiteazn2's Avatar
Whiteazn2
Who listens to cds? Just get aftermarket indash and u can listen through bluetooth.
Old Feb 9, 2014 | 11:34 AM
  #64
Jah70's Avatar
Jah70
Or just get a transmitter that can do both.
Old Feb 10, 2014 | 04:45 AM
  #65
Saberspark's Avatar
Saberspark
Thanks. And yeah, I didn't know their output would be as bad as it is. I was hoping I wouldn't have to replace them so early on.
lol yeah, they put a little gas in for me, and I filled up the rest.
Don't remember if I mentioned it in my last post, but now I notice a burning oil smell. Wunderbar.
Old Feb 10, 2014 | 05:14 AM
  #66
Jah70's Avatar
Jah70
That is odd. Did you thoroughly inspect it before you bought it? Check all fluid levels, look underneath the car for any rust, leaking lines etc.? I started my Z up recently and smelled a burning oil smell but that is because I got a little bit of WD40 on the exhaust by mistake. Unless you or the dealer coated the undercarriage with oil and accidentally got some on the exhaust by mistake you shouldn't smell anything besides the exhaust somewhat having a weird smell when you first start it up but goes away. Did you have the heat on full blast? Did you smell it from the inside with the doors and windows closed or can you smell it coming from the outside of the car? Did you eat any Mexican food causing you to accidentally rip *** but didn't know it? That could also be it too.
Old Feb 10, 2014 | 06:11 AM
  #67
allshownogo's Avatar
allshownogo
who listens to music? i tend to roll my windows down and enjoy the engine and exhaust note.
Old Feb 10, 2014 | 06:32 AM
  #68
Saberspark's Avatar
Saberspark
I didn't look under the car, to be honest. As far as when I smell it, I can sometimes smell it through the car with windows up.
Old Feb 10, 2014 | 06:34 AM
  #69
Syner's Avatar
Syner
Get under and check for leaks.
Old Feb 10, 2014 | 07:27 AM
  #70
Saberspark's Avatar
Saberspark
Yup yup. That's all going to have to wait a bit as I didn't drive the car to work today. Roads are a bit messed up from the seemingly never ending waves of snow, the most recent being last night. Took the Blazer instead.
Old Feb 10, 2014 | 07:30 AM
  #71
Syner's Avatar
Syner
good call.
Old Feb 10, 2014 | 10:17 AM
  #72
Jah70's Avatar
Jah70
I hope your keeping the blazer as a backup.
Old Feb 10, 2014 | 10:23 AM
  #73
TuckerE36's Avatar
TuckerE36
Op said he's keeping the blazer as a beater if I'm not mistaken.
Old Feb 10, 2014 | 11:14 AM
  #74
soc_monki's Avatar
soc_monki
the smell could be from the seal where the driveshaft enters the transmission. mine has a slight leak there, and its right over the Y pipe, and you can smell it. i need to get the seal and see how much my guy is going to charge me to change it, but it shouldnt be much (i hope). the seal is cheap, about 6 bucks. if i had a way to get the car up i would do it myself, but at the moment i dont.
check and see if you have a drip around the Y pipe after driving. i have the Nismo exhaust, so it allows the fluid to drip on the ground when im not moving. not sure if the stock y pipe blocks it or not...but its something to look at.
Old Feb 10, 2014 | 11:20 AM
  #75
Saberspark's Avatar
Saberspark
Right you are. Keeping it for days like today. And my dad is taking it to have the radio issues checked out tomorrow. And then I'll need Blazer again on Thursday, maybe Wednesday depending on what time the snow starts again
Old Feb 20, 2014 | 12:48 PM
  #76
Looks nice but why does your shifter say P, D and N?
Must be a race car!
Old Feb 20, 2014 | 04:59 PM
  #77
sportyaccordy's Avatar
sportyaccordy
If the roads in Philly are rough pass on the Z. I drove my Z up to NYC to visit and hated it. The roads beat the **** out of it
Old Feb 21, 2014 | 06:42 AM
  #78
Justin100's Avatar
Justin100
Originally Posted by davidv
Must be a race car!
probably decided to go to aventador/F1 formula race car route
JjL
East Canada
Jun 12, 2019 03:04 AM
416blueZ
Sep 25, 2015 10:00 AM
RyansZ33
Sep 15, 2015 05:54 AM
pdexta
Sep 14, 2015 11:27 AM
issyz
Sep 10, 2015 02:00 PM
