Waxing method??
Old Nov 21, 2002 | 01:14 PM
nosuchsol's Avatar
nosuchsol
Default Waxing method??
Hello,
Generally when I wax the car I don't use swirling for puttin the wax on or off. I go up and down. Now I heard that some people put three coats on... one vertical, one horizontal, then one diagonal... dry and buff between each coat. Does anyone know if that makes a difference?
Danke,
Drew
Old Nov 21, 2002 | 03:46 PM
nbdyfcnsqnc's Avatar
nbdyfcnsqnc
I think hand swirling makes the most sense, because that will make sure the first coat gets into all the places it should. That's what makes a wax effective.
I'm afraid if you apply one coat with one motion, you'll cover up a scratch or pit without totally filling it with wax. Then the second coat won't be able to do its job.
Old Nov 21, 2002 | 03:50 PM
nosuchsol's Avatar
nosuchsol
All the instructions I've read beyond turtle wax have been an up and down motion. It works nicely. I just spot-tested on my car to see how it works against swirlmarks... it works well but it's better to remove in a circular fashion. I guess each will work just depends.
Old Nov 21, 2002 | 09:18 PM
nbdyfcnsqnc
Hmm, yeah, now that you mention it, I guess it makes sense if you already have swirl marks and want to get rid of them. That way, if you're only moving in one direction at a time, you'll fill all the crosswise parts of the swirl without pushing any wax back out.
Old Nov 21, 2002 | 09:49 PM
ares's Avatar
ares
Veteran
I go up and down the side panels, and front to back on vertical panels... as zaino directions indicate... and I refuse to acknowledge swirl marks.
Old Nov 26, 2002 | 04:49 AM
DUKE's Avatar
DUKE
Shouldn't that be rub front to back on horizontal surfaces (top panels) and up and down on vertical surfaces (side panels).
Siqcology
Sep 18, 2019 01:45 PM
dcains
Sep 21, 2015 09:28 AM
Slexis200
Cleaning & Detailing
Oct 9, 2002 02:40 PM
tranZition
Oct 5, 2002 06:48 PM
Brad4rdHay
Sep 2, 2002 06:56 PM
