Cleaning Headliner in 350Z?
Old May 17, 2005 | 06:57 AM
yanotkaj's Avatar
yanotkaj
Default Cleaning Headliner in 350Z?
I need to clean the headliner in my 350Z. What can I use to do this?
Old May 17, 2005 | 07:03 AM
VandyZ's Avatar
VandyZ
I used a 10:1 Water:Woolite solution sprayed on a terry cloth and rubbed gently. The grease mark came off and left no spots.
Old May 18, 2005 | 09:50 AM
NOBI's Avatar
NOBI
so its just water and woolite no prep, just wet the cloth and go?
Old May 18, 2005 | 11:00 AM
VandyZ's Avatar
VandyZ
yes, dont spray the liner . . .I think that would leave a water ring.
You can move up to a 7:1 solution if the 10:1 does not work.
Headliners are funny cause its easy to make them look worse by trying to clean them.
Old May 18, 2005 | 08:06 PM
Reese's Avatar
Reese
I wiped some spots of something off of mine with just a damp cloth. Seemed to work fine. Guess it depends on what the stain consists of.
Old May 19, 2005 | 06:37 AM
bigFenE's Avatar
bigFenE
when I got my used '03, the guy had smoked like a chimney, the bastard!
I used this twin-tubed Oxy-type cleaner that came with the two tubes next to eachother with a sprayer attached to the two of them. Home depot had it.
It worked AWESOME. Sprayed it all over and whiped with a moist terry cloth towel.
Here it is, I searched for an hour to find it, so I hope it helps!
http://www.bissell.com/Products/prod...+Stain+Remover
JjL
East Canada
Jun 12, 2019 03:04 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
davidm350
Oct 31, 2015 02:28 PM
RyansZ33
Sep 15, 2015 05:54 AM
