Polished lip on rims and cleaning. . .
Old Aug 29, 2005 | 09:36 PM
JamRWS6's Avatar
JamRWS6
Originally Posted by GQ 350z
BUmp...need some help guys! How do I keep the wheels blingin? They look stupid sweet when they are clean, which lasts like a day with the way I drive. The brake dust cakes the lip and makes it look like hazy. Soap/water works great, but what can I do to keep that look?
ravi
Polish them up.....and then put a protective coating on them.
Since there is no way to keep the brake dust off you'll just have to wash them regularly which should be made easier with whatever wheel protectant you use.
I just use Zaino on mine and that works out well.
Also try out Mother's Powerball......it will save you some time.
Old Sep 10, 2005 | 05:17 PM
microsteve40's Avatar
microsteve40
Know it all
ravi
I've been using the normal rinse, soap and water routine to clean my wheels (Volk GT-V), and I had been using Mothers Mag and Aluminum Polish on the lips, which worked well. But, this week I recieved my Wheel Wax, and used it today for the first time, and the wheels look SPECTACULAR!!!! They are so shiny and look as good as new. I also bought the Wheel Wax Metal Polish, but luckily, I read the package before I used it. It doesn't say so on the website, but the package on the Metal Polish says "not suitable for use on anodized, clear coated, or plated surfaces." From what I've heard, the spokes on the Volks are anodized, and I know the polished lips are clearcoated. I'm going to call the Wheel Wax company ASAP and find out if the Wheel Wax will be safe for the spokes also. Anyway, just clean the wheels up and then use the Wheel Wax and they will look phenomenal! And do this often. Keep the wheels clean, don't allow for buildup over a long time, and you should have no problems.
Old Sep 10, 2005 | 09:48 PM
BhashaZ's Avatar
BhashaZ
You stated that you used Mother's Mag and Aluminum polish on the lips, but I thought the Volk's lips are clearcoated? When you use the polish, did your rag become black?
When I used the Mother's Mag polish on my exhaust tips, I got the rag to turn black. However, I haven't tried it on the lips of my wheels since they're clearcoated.
Old Sep 10, 2005 | 10:36 PM
atar350's Avatar
atar350
****ATTENTION****
Do not, I repeat do NOT use any products on your clear coated rims, Volks, iForged, Racing Hart......I found out the hard way, I used Meguiars Hot wheel cleaner, and it ate my clear coat so bad on one of the wheels a few small chips came off the center cap. Not to mention my wheels were not smooth, and hazed....I went to Kragen, looked at every wheel polish they had, including that Blue stuff, all of that stuff is NOT meant for the machined clear coated wheels....NONE OF IT. Read CAREFULLY, it is not for clearcoated wheels.
Wheels like the above mentioned need to be treated like a car, I for now on am just using soap and water, I always use the DIY Coin Wash places to clean my car, and I use the high pressure soap to blast my wheels, including the inside (for the guy that asked) I noticed the inside getting really dirty, go to one of these coin wash places and blast the inside clean. Anyways, after my wheels were hazed and not smooth, I figured out it was the product I was using from Meguiars, so I washed them really good with high pressure soap, and then a high pressure water blast that got them dust free inside and out, after that I dried them completley and applied some Meguiars Gold Class car wax to the lip and spokes...let them dry, wiped clean, then did another coat on all of the rims, wiped clean, and they were brand new. The Clearcoat wasnt hazy AT ALL, and the rims were silky smooth once again. So dont use any products, I dont even trust the wheel wax stuff for the clear coat, I saw it online but wasnt convinced, I will stick to car wax.
Old Sep 29, 2005 | 06:15 PM
imalazeeass's Avatar
imalazeeass
So for the volk lips it is best to just use the same zaino wax that you use on your car? I was really looking forward to try out that wheelwax.com site since I've read so much about it. Surely, if so many people are using wheelwax.com it should be a good product. Is there anyone out there that has had a BAD experience with wheelwax.com?
Old Sep 29, 2005 | 06:58 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Shouldn't you clean the wheels first so that you don't get dirt and water all over your car again?
Originally Posted by KShep
Almost impossible to avoid the fine, hairline scratches on polished lips.
I clean the wheels last, with a new bucket of soap and a fresh lambs wool mitt. Use the pressure from the spray nozzel to remove as much surface debris as possible, then sopa up the mitt and gently clean the rim. If you have a leaf blower or air compressor use that to dry the wheels, follow up with a MF or DF towel. Wenol Blue or NXT All Metal Polish, among others, will remove surface oxidation without harming the finish (assuming no clearcoat on the rim).
I never use a brush. If you don't have a good lambs wool mitt, a clean, 100% cotton towel will work fine. Whatever you use, keep a bucket of fresh, clean water nearby and rinse out the mitt or towel as needed to remove grit and dirt that could damage the wheel.
Useful info can also be found at autopia.org, or in the detailing section of these forums.
https://my350z.com/forum/cleaning-and-detailing/96116-polisihing-lip-on-rims.html
Old Sep 29, 2005 | 07:10 PM
DavesZ#3's Avatar
DavesZ#3
I clean my wheels first - but for the reason of not getting water spots on my car. If you wash your wheels last, while you're washing them the soap on your car is drying. If you rinse your car then proceed to wash the wheels, then you still risk having the water dry on the car while you're washing the wheels.
I use a soft cotton cloth and a wheel brush to wash my wheels. After washing them, I pour out that soapy water and rinse the bucket before preparing the soapy water for washing the car. Nothing that touches my wheels ever touches my paint so I don't have to worry about brake dust and road grime scratching it.
Old Sep 29, 2005 | 07:25 PM
350ztoronto's Avatar
350ztoronto
i used the aftermarket "spray and rinse" on my 5zigens on my accord before it ate the friggen clear coat and made it peel!!!!
Old Sep 29, 2005 | 09:53 PM
imalazeeass
what happens is that if you have a deep lip... well most of the whees people buy do so what happens is that when you wash them, it builds up a huge puddle of water inside the rim. It's hard to see and not noticable at all so once you finisn and start driving, the water gets all over your wheels again. So you gotta soak up tha water inside and you shouldn't really have any waterspots after that. It's a pain in the *** but it helps a lot.
Old Sep 29, 2005 | 09:56 PM
BhashaZ's Avatar
BhashaZ
Yup, I HATE that! But yeah, soak up as much as possible with a rag.
Old Sep 30, 2005 | 12:05 AM
microsteve40
Know it all
The Volk lips are clearcoated. I don't remember the rag turning black on me. And the Mother's worked just fine on my Volks. The lips looked really good actually. I wouldn't worry about the rag, the wax and polish gets off a lot of the dirt and grime that's still there even after a wash. As long as it didn't do any damage to your tips, you should be fine. As always with a new product, read the instructions, and then test it on a small area, so you don't ruin the whole thing if there are problems.
Old Sep 30, 2005 | 12:13 AM
microsteve40
Know it all
Just so everyone knows, some of the WheelWax products ARE SAFE for use with clearcoated and anodized wheels. The WheelWax metal polish is NOT one of these products. When I bought it, it didn't say so on the website (not sure if it does now), but luckily I read the instructions and never put it on my rims. However, the auto shampoo and the WheelWax itself is safe for clearcoated, polished, and anodized rims. I have used both products on my rims, and they come out looking SPECTACULAR! I used the WheelWax on both the spokes and the polished/clearcoated lip.
Also, if you have any questions about their products, don't hesitate to ask them. They are a first-rate company when it comes to customer service. I had ordered the metal polish and the WheelWax, and when I found out the metal polish was not safe for clearcoated and anodized rims, I sent them an email on a Sunday evening, stating that I would've spent the money on another product, like the auto shampoo or the tire dressing. When I woke up Monday, I had an email from them apologizing for the confusion and saying that I could keep the metal polish (instead of returning it for a refund, which wasn't worth it) for use on other household items. The also said they would send me the Auto Shampoo and the tire dressing free of charge, and shipped it out that same day. When I returned home to Boise from San Jose on Friday, my package was waiting for me. I will be doing all of my wheel care business with them in the future. Their products are fabulous, and their customer service is top notch!
Old Sep 30, 2005 | 02:21 AM
showstoppertk's Avatar
showstoppertk
I (like every Z/G owner) experienced the infamous front brake dust problem. I remedied it by changed to a low dust pad (in my case Hawk HPS) and also putting wheel wax on my entire wheels. Now it takes weeks for my rims to get much dust/dirt on them, even if it rains. I'd say that will definately solve any brake dust problem. as for cleaning them I NEVER use any spray on wheel cleaners/solvents/polishes. like most guys here will tell you, you should treat your rims like you would the hood of your car if not better. you probably paid big bucks for them and they likely have a clear coat so treat them as such (if your using a brush on them and wondering why they scratch then you may have bigger problems). I always wash my wheels last with a light car wash soap, water and a good quality mitt, then I dry with my leaf blower, then I wipe down with a microfiber towel, then I use wheel wax maybe once a month.
Old Sep 30, 2005 | 03:07 AM
wayneside's Avatar
wayneside
like some of the guys here...i just use a fresh bucket of meguiars nxt soap/water and wipe my volks down...i go gently over them twice and rinse them off...and to dry them, i use my meguiars microfiber cloths...
Old Sep 30, 2005 | 03:57 AM
DavesZ#3's Avatar
DavesZ#3
One of the advantages to using a leaf blower for drying your car is that you can blow the water out before you take off driving in the car.
Old Oct 2, 2005 | 08:38 PM
Mc556's Avatar
Mc556
Originally Posted by g6g35
I have a jar of blue magic that I was planning to use, is this safe on volks rim and lip?
No it will eat through I found this out the hard way on my Volk GT-AVs
Old Oct 12, 2005 | 05:05 PM
hutchdelrosario's Avatar
hutchdelrosario
i ruined my volk racing wheels using the meguiar wheel cleaner "damn"....
does anyone know where i can get my wheels back to standards???
pls help... i just got 2 weeks ago and my wheels are lookin so bad right now...
