claybar dulled my paint!
Old Aug 9, 2005 | 06:46 AM
fireballtaft's Avatar
fireballtaft
Default claybar dulled my paint!
I had tree sap on a few spots on my car so i used the claybar from the zaino detailer kit and it took a lot of rubbing on each spot...I made sure it was well lubricated and most of the sap finally came off but now when it catches the sunlight it looks a little dull even after a z-7 wash and z-5 and z-6. Is there anything i can do to make it look better and get the rest of the sap off?
Old Aug 9, 2005 | 06:49 AM
bstansbu's Avatar
bstansbu
Sorry but I dont think so, just be glad you didnt do what my brilliant sister did to her new pathfinder this week. She had tar on the front and a little on the hood, so she thought it would be ok to put bug and tar remover and just scrub away with an ebrasive green one sides scouring pad you use for pots and pans. hahahah Poor girl. She called me crying, I was like, no your kidding right? She wasnt!!! BEN
Old Aug 9, 2005 | 07:47 AM
A_16's Avatar
A_16
well.........did u wash the car before clay barring it and how long had this sap been on there. Nissan paint is not the strongest, bird poo made my last nissan have a bit of a fade spot. My experience with clay(I used on Z as well) is it is extroidinary on bringin the paint back to life, sorry it didn't work out for you though.
Brett
Old Aug 9, 2005 | 08:14 AM
Them Bones's Avatar
Them Bones
Did the sap eat into the paint? If not, you probabaly just need to polish it. Zaino isn't polish, AFAIK. Try Meguiar's swirl remover. It's a VERY mild abrasive polish.
If the sap did eat into the paint, you could have someone airbrush some more clearcoat on the area, then buff to blend it.
Old Aug 9, 2005 | 08:21 AM
bixby's Avatar
bixby
Porter Cable & some liquid rubbing compound will remoe it. I had this problem (biefly) with my Z32. Once complete there was no sign of sap and absolutely no dulling.
Then just start layering the Zaino again.
Old Aug 9, 2005 | 08:25 AM
fireballtaft
The sap was on there for about 2 days and i don't think it ate the paint at all...there is still a little clear spot of sap on there though...thanks for all the help.
Old Aug 9, 2005 | 08:32 AM
Audito350Z's Avatar
Audito350Z
you need Menzerna... start with the Intense Polish, then use the Final Polish... for a small section you can do it by hand, for large sections, use a Porter Cable.... you can Zaino over that all you want
Old Aug 9, 2005 | 08:39 AM
fireballtaft
When I use the polish do i first have to remove the zaino i applied or can i just polish over it and then zaino the car again?
Old Aug 9, 2005 | 08:42 AM
HotFairladyZ's Avatar
HotFairladyZ
I think you should just be able to start the Zaino again... I'm suprised you had problems. I've never had anything but great luck with Zaino.
Old Aug 9, 2005 | 09:59 AM
bixby's Avatar
bixby
The polish wil remove the Zaino so no need to worry about it. Of course since you want the car to be clean when you start it wouldn't hurt to just wash with Dawn. No need to use Z7 since you'll just be polishing off your Zaino anyway.
Old Aug 9, 2005 | 11:32 AM
Netko350Z's Avatar
Netko350Z
DrBonz is on vacation...I am sure he would give some advice...
Old Aug 9, 2005 | 12:29 PM
Act of God's Avatar
Act of God
This may sound weird, but Olive Oil will take sap off amazingly well. I just did my parent's cars this weekend (we live in the woods). Olive Oil breaks down sugar, which is what sap is mostly.
this, of course, wasn't after my dad ruined the hood of my old 3000gt using the OTHER SIDE OF THE SPONGE trying to get it off.
Old Aug 9, 2005 | 01:15 PM
Audito350Z's Avatar
Audito350Z
like Bixby said... no need to remove the Zaino.... just wash the damaged section with your normal car wash soap to make sure there's no dirt or whatever, then get on with the polishing...
Old Aug 9, 2005 | 01:26 PM
arvin's Avatar
arvin
LMAO, my sis did the exact same thing.
Old Aug 9, 2005 | 02:27 PM
B-Unit's Avatar
B-Unit
im sure the claybar didnt dull the paint, ive claybared my car several times and its just fine.
Old Aug 11, 2005 | 11:01 AM
fireballtaft
When i polish, do I polish the whole car or just the faded tree sap spots...i don't want it to be uneven at all...thanks for all the advice.
Old Aug 12, 2005 | 08:32 AM
Maelstrom's Avatar
Maelstrom
When you did the claybar what did you use as lube? lots of body gloss products that people use as lube shouldn't be used if there is direct sunlight because they leave a really crappy look in the end. Also remember to wax after (i have no clue what zaino products in your post are)
Old Aug 12, 2005 | 08:59 AM
bixby's Avatar
bixby
If it were me, I'd do the hole car. Probably not required but thats just me.
Old Aug 12, 2005 | 12:13 PM
sharingan625's Avatar
sharingan625
use 3M mild cut rubbing compound and 3M swirl remover. you don't need a machine to do this. just rub with some towel (i used MF towel) with rubbing compound, and finish off with the swirl remover.
i had to use these to take out tree sap, bird crap eating up the clear coat. works everytime. as long as the paint is still there, this can bring up the shine again.
be aware tho. you will have a swirl-free spots after using these.
Old Aug 12, 2005 | 12:42 PM
muscleknight's Avatar
muscleknight
Default 3M All Purpose Cleaner
3M All Purpose Cleaner will get sap off and it won't hurt the paint. It does remove wax so take the tip of a towel, dab it in the can to get some solvent on the towel then gently rub off the tar or sap. Just try to get the tar or sap spot. You can get the 3M Cleaner at auto paint supply stores.
