brake dust on volks gtcs
Old Aug 24, 2005 | 09:27 AM
NVthis350's Avatar
NVthis350
Default brake dust on volks gtcs
I have been trying to clean the brake dust off of my volks but there is still some that isn't coming off. I have tried tire cleaner and rags. Any suggestions?
Thanks in advance.
Old Aug 24, 2005 | 09:29 AM
engiNERD350Z's Avatar
engiNERD350Z
Claybar? Althought I have no prior experience doing it on wheels.
NVthis350's Avatar
NVthis350
what's clay bar?
Old Aug 24, 2005 | 09:32 AM
engiNERD350Z
http://www.autogeek.net/motcalgolcla.html
Its typically used for paint. The clay shears off the contaminants left on the surface of your car. If you notice after you wash your car, you feel little particles still stuck on the paint, claybar gets rid of these and makes your finish perfect again. Its a miracle worker. I suggest Mothers based upon experience and reviews.
Old Aug 24, 2005 | 09:35 AM
NVthis350's Avatar
NVthis350
hmm sounds interesting what about polishing compound? or metal cleaner?
Old Aug 24, 2005 | 09:47 AM
Nano's Avatar
Nano
toothpaste
Old Aug 24, 2005 | 09:50 AM
crjpilot's Avatar
crjpilot
Simple Green and some scrubbing with a wheel brush worked for me. I had some nasty dried on brake dust. It's work, but it'll come off. Get yourself a good brush from an auto store and use the heavy cleaning mixing ratio for mixing the Simple Green with water.
Old Aug 24, 2005 | 10:10 AM
NVthis350's Avatar
NVthis350
sounds good. thanks guys. toothpaste eh? whitening? or tartar control?
Old Aug 24, 2005 | 10:15 AM
ZinMiami's Avatar
ZinMiami
Colgate Complete!
Old Aug 24, 2005 | 10:24 AM
jcandas's Avatar
jcandas
Zymol wheel cleaner is hands down, the best I have tried. I only needed a soft horsehair brush to wipe away the caked on brake dust after letting the spray sit for a minute.
It isn't cheap, but if you think your wheels are worth it, buy it.
BTW, it is also made from plant extracts and is environmentally friendly.
Old Aug 26, 2005 | 03:55 PM
Default You spent $2,000 plus on some buetifull wheels...
treat them with care. Whatever you would NOT put on the paint, don't use on the wheels. That said, try:
a 50/50 mix of Mr. Clean and water in a spary bottle. Rinse with a hose, then spray with the solution. Then let it sit. Let time work its majic. Clean with soap and water.
Gunk Bug & Tar works well, and is mild.
Wax the wheels as usual to protect then. One key is to clean the wheels BEFORE they get dirty.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
