Zaino: How thin is thin??
Old Feb 2, 2003 | 11:51 AM
afr0puff's Avatar
afr0puff
Question Zaino: How thin is thin??
When do I add more zaino to the applicator pad? Until it stops applying zaino? Also, should i be using more than one applicator pad? I just finished my first coat of Z5 all with one applicator pad, but I used both sides.
Dr BONZ... I passed the plastic pag test! You'd be so proud of me! I was really disheartened when I was claying the car. I thought I was using too much lube. It was about 40 degrees and the clay would not bend, stretch, fold or anything. It felt like i was taking a bar of soap over the car. Then after I cleaned and dried the car, I put my hand in a plastic bag... Smoove as glass!!! as compared to the time i did it before claying.
Old Feb 2, 2003 | 12:25 PM
ares's Avatar
ares
Veteran
just a note, be sure to remove the plastic that is like ON the clay... I didnt and I couldnt figure out why it wouldnt bend or stretch. after that it bent and stretched quite nicely.
as for thin, I think you go till it stops putting down a cloudy mark, as long as its coating its thick enough.
I ussually mist the applicator with the spray stuff, makes the wax go farther.
Old Feb 2, 2003 | 12:52 PM
afr0puff's Avatar
afr0puff
HAHAH! I can't believe you openly admitted that When I removed the wrapper, I was like WTF?! Then I noticed that it still had plastic on it. I think heat plays a great deal in the amount it bends and stretches. There is no way in hell mine looked anywhere near what Bonz, clay looked like. Mine looked like a retarded rubber ball when I was done with it. I have a coat of Z5 fermenting on it now. I think i may have put it on too thick.
Justin100
Nov 29, 2015 03:58 PM
MrSpiffy
Cleaning & Detailing
25
Jun 2, 2005 05:15 AM
vice86
Sep 20, 2003 06:51 PM
drivesolo
Jun 25, 2003 10:10 AM
