question about zaino
Old Aug 4, 2006 | 10:33 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by highside107
Hey guys, I had a detailer Zaino my car (Dawn, clay, Z2, Z5, Z2, Z6, I think) and am going to polish in the near future. I know this strips it off, but when I go to "reapply", will it be as if I had never Zaino'd before (and have to start from step 1) or could I just throw a coat or two on and be fine? Let's assume I Zaino the car a day or two right after polishing. Thanks.
What product do you plan on using to polish?
Old Aug 5, 2006 | 02:59 PM
highside107's Avatar
highside107
I don't know the first things about polishes, lol.
Old Aug 6, 2006 | 05:35 AM
DavesZ#3's Avatar
DavesZ#3
And that's probably why he asked. First off, some people use the term "polish" interchangably with "wax". Real polishes have abrasives that remove a small amount of paint and are typically used to cleanup paint problems and imperfections.
Because they remove a microsopic amount of paint from the surface,they also remove any waxes you have on your car. If you polish a Zainoed car, you remove it in the process so you're starting with a clean Zainoless surface. That's why in my last post I mentioned that you don't need to do the Dawn wash and claybar because in theory, you're starting with a fresh clean surface.
If you don't know the first thing about polishes, then I would suggest that you NOT use one on your car. If done improperly, all you'll do is scratch up the surface.
Is there a particular problem that you're trying to solve by polishing (i.e. swirl marks, scratches)?
Old Aug 6, 2006 | 11:27 AM
highside107
Yeah, actually I took Mother's Fine Cut Cleaner (a polish I think) to a section of my car with a microfiber cloth (I know, I know, very bad of me) and it left a lot of those little swirly scratches which are only visible if you look at it at a certain sunlit angle. Don't ask why I did it in the first place; let's just say I am a noobie. So I know that I'm going to need to polish/re-polish that area but this time with a PC Orbital to get it off, correct? I'm also thinking about polishing because the DB color on my Z doesn't look as "deep" and dark as other DB Z's I have seen so I want to try and bring back that color.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
