Old wax spots?
Old Aug 22, 2006 | 09:08 PM
Bday350z's Avatar
Bday350z
Default Old wax spots?
I have an 03 PPW Z, and I just bought it a few weeks ago and when I was cleaning it the first day I noticed that scattered in places you wouldn't normally look on the car that there are spots of what looks sort of like white mortar, but I think it's wax that's been there for atleast months, what should I do to remove the spots goo gone sort of works but some is still there.
Old Aug 22, 2006 | 11:07 PM
mrZeee's Avatar
mrZeee
wax over it..then remove..or polish
Old Aug 22, 2006 | 11:18 PM
A good one-step should remove old wax residue.
Old Aug 25, 2006 | 06:00 AM
Bday350z's Avatar
Bday350z
Then maybe it's not wax, because I've gone over all of the spots atleast three times and some are still there.
Old Aug 25, 2006 | 07:32 AM
panapower's Avatar
panapower
ok, did you wash the car? what products did you go over the spot with?
Old Aug 25, 2006 | 08:29 AM
usmanasif's Avatar
usmanasif
If it indeed isn't old wax, try a bug/tar remover.
Old Aug 25, 2006 | 11:26 AM
RedLeader's Avatar
RedLeader
If you've only had the car for a few weeks, you may want to strip the old product off and give it the full treatment. You can buy wax removal spray from Griots Garage or use Dawn dish soap. If that doesn't remove it, bug & tar remover, clay bar, or WD40 are probably your next steps.
I've seen pitch from trees that got sort of "powdery" looking over time. It can be a real ***** to remove. Saturate it and hope it loosens-up.
Good Luck,
Bruce
Old Aug 25, 2006 | 11:32 AM
SteveZ's Avatar
SteveZ
Sounds to me like tree pitch allowed to sit long time before cleaning. Have seen that on my own car when it had to sit outside. Recommend Mother's Cleaning Wax and may try clay bar too. Follow with a Sealer; the haze sounds like it penetrated the very top of the clear coat. Follow with a good wax on top of the sealer.
HTH
Old Aug 25, 2006 | 11:53 AM
Bday350z's Avatar
Bday350z
Thanks guys I'll try it out.
Old Aug 25, 2006 | 12:38 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
clay bar may be your best bet... it usually removes contaminants better than a cleaner/wax
Chris350z03
Oct 8, 2023 07:19 PM
pslamp32
Feb 8, 2017 09:07 AM
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
dcains
Sep 21, 2015 09:28 AM
