Window Cleaner
Old Nov 18, 2006 | 04:15 PM
joekool's Avatar
joekool
Default Window Cleaner
Guys, was just wandering what you use as a glass cleaner??? I'm looking for something that beads the water off your windows effectively. Thanks.
Old Nov 18, 2006 | 04:19 PM
microd's Avatar
microd
Clean them with Windex, then wax them -- outside not inside. That's what I do. The water beads up pretty good.
Old Nov 18, 2006 | 04:50 PM
DavesZ#3's Avatar
DavesZ#3
Nothing beats Stoners Invisible Glass.
Windex may be okay for the outside, but not the inside. It contains ammonia which can be harmful to plastic, vinyl and leather interior pieces.
I also use crumpled newspaper to wipe the windows. It leaves absolutely no lint or streaks behind.
Old Nov 18, 2006 | 04:56 PM
zand02max's Avatar
zand02max
I use Zaino Glass polish, works wonders in filling in the small chips and getting rid of the haze on the inside as well.
Old Nov 18, 2006 | 05:43 PM
SB04's Avatar
SB04
I clean the outside with car wash, same as the rest of the car...dry them good...and wax them just as I do the car...I use Zaino also, but just the Z-2 and Z-5...you can wax it with whatever you are doing your car with...the water rolls right off, almost no need for wipers on the highway
Old Nov 18, 2006 | 05:50 PM
I wax the front window when I wax the car. Same stuff.
Old Nov 19, 2006 | 08:51 AM
Z04's Avatar
Z04
Stoners, hands down the best.
Old Nov 19, 2006 | 05:12 PM
joekool's Avatar
joekool
Thanks for the informative posts guys. Should I:: wash -> wax -> stoners or:: wash -> stoners -> wax. Or use only one or the other?
Old Nov 19, 2006 | 06:38 PM
Swiffer's Avatar
Swiffer
+1 on the Stoners.
Old Nov 19, 2006 | 06:39 PM
Swiffer's Avatar
Swiffer
wash -> either stoners or wax.
I'm thinking the stoners will remove the wax if you apply it first. You can probably wax over top of the stoners without any problems.
Old Nov 20, 2006 | 09:57 AM
mrZeee's Avatar
mrZeee
megs NXT glass cleaner...topped with rainx...rainx window wash in resevoir
Old Nov 20, 2006 | 10:26 AM
Cannysage's Avatar
Cannysage
I use this $5 stuff in a black bottle. stuff is very strong and works wells. then I coat it with rainx.
Siqcology
Sep 18, 2019 01:45 PM
pslamp32
Feb 8, 2017 09:07 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
AP350z223
Sep 8, 2015 04:38 PM
