Detail spray, always have to use Z-6 if Zaino'd?
My car has 5 coats of Zaino on it. After I'm done washing and drying the car, i like to z-6 the car. However, I am running low on Z-6 and the stuff is pretty expensive. Can I use another detail spray to work with Zaino? I'd rather save the Z-6 for whenever I apply a coat of Zaino.
I always wash, wax, then let it dry over night, the next morning I remove the wax(I dont use ZFX) but I dont really care to start detailing the car beyond removing the wax, so I never use the stuff... hasnt caused me any trouble, might not shine as much, but it doesnt affect its protection, which is really what I want out of it...
vicmar90 asked a while back:
“My question is that I ran out of the Z-6 Gloss Enhancer and in the interim am using the Meguiar Quick Detail in-between and after car washes. I am in the process of ordering more of the Z-6, however, in the meantime is there a major difference between these two products?”
Brad4rdHay replied:
“If you want to save some money, buy a gallon of Meguiar's Final Inspection (the "Quick Detailer" has silicons in it). Final Inspection is a very slipery, expendable QD spray.”
https://my350z.com/forum/showthread....r&pagenumber=2
afr0puff, if I were you I would e-mail Sal and ask him what would be safe to use if you run out of Z-6.
Keep us informed on what you do.
Brad4rdHay replied:
Sal's reply...
No!!!!. Please Do not put any other detailer on top of Zaino.
_ Zaino Show Car Polish is 99.9% optically perfect. Do not put anything on
_ top of Zaino except Zaino. That would defeat the whole purpose of my
_ product.
_ Z-6 and Meguiars detailer are two completely different products.....
_ Stay away from other brand Quick detailers. They are not
_ compatible with Zaino. Z-6 is chemically designed to bond to Zaino polish.
LOL! No joke, he did bold that first line in his reply to me.
_ product.
Originally posted by afr0puff
Sal's reply...
_ product.
Sal's reply...
_ product.
I've been using Zaino products for almost a year. No doubt it creates a nice smooth shinny finish.
After 5 coats of Z2 (I'm coming DrBonz's!) I use the Z6 all the time but I did try half a hood with and half without. Honestly I couldn't tell any difference.
What I use it for is touching up the car, clears water spots (after a quick run out).
Does anyone really really see an obvious change or difference. Remember I already own the stuff and have purchased more of it so don't flame!
Just looking for confirmation of what I don't seem to see!
I've only noticed a difference in dust pick-up and how much smoother it is. After I wash and dry the car, the surface is pretty slick. But after I Z-6 the car, it feels like glass. I can't even keep a towel on the hood. Slides right off.
Guest
Posts: n/a
Sal's reply...
_ product.
Sal's reply...
_ product.
I can vouch for this. I tried a little QD with Zaino on and it hazed and was a nightmare. Use all Zaino or all Megs.
~Jeron
You don't need to use Z-6 every time you polish. I recommend you use it BEFORE polishing (to make sure you have your surface as clean as possible before polishing). Following up with Z-6 will help clean up any remaining polish residue, and also help cut down on "static cling" that tends to attract dust. I'd recommend you do that the day AFTER you polish.
As for diluting Z-6, the old formula did yeild good results when you diluted it with distilled water. This was usually helpful when you were using it as a quick clean-up on a car that was in the sun. In this case you would spray a towel with Z-6 and wipe the car with the moist towel (you shouldn't spray Z-6 on a hot car, as it will dry too quickly and can leave streaks). The current Z-6 formula doesn't need dilution.
If you use it sparingly, Z-6 will last a LONG time. You've just got to make sure you get a super-fine mist. If your towel ends up wet, you're probably using too much.
Just to stick up for Sal, he *does* recommend other company's products - WHEN THEY WORK! I've been working with him for at least 5 years, and he has told me to go buy non-Zaino products to work on specific problems. However, when it comes to Z-6, I haven't found a substitute that adds UV protectant, doesn't add oils (which turn your car into a dirt magnet) and doesn't dull the finish. If you did find such a thing, would it be less than $9.95?
Doug
Showcars of Texas
Authorized Zaino Distrubutor
512-310-8174
Doug
Showcars of Texas
512-310-8174
I thought that you were supposed to apply Z-6 after each and every coat? Going to really get down to business this weekend. Been dying to apply some Zaino on my G35 coupe. Hope to get at least two coats of Z-5 in and two or three more of Z-2 with Z-6 all up in between it. Plus some claying. How long you think that will take? 6 hours?
that's FIVE coats you want? that's a lot of waiting time for the coats to dry, even with zfx, i think. Am I right?
Well, I finally did it. Started Friday morning. Dawn wash, followed by clay bar. Man, that clay bar is a PITA. Didn't pick up too much, seeing as how my G coupe is new, but it did pick up some minute pieces of dirt. I was a little tentative at first, but with enough lubricant, I was able to really get at the dirt. Followed up with two coats of Z-5 with Z-6 in between each coat. Didn't have to wait long for it to cure. Put it on, and after I finished the whole car, started taking it off where I first started. I was hoping the Z-5 would cover the small scratch I accidentally put on the bumper, but it didn't. I was stupid and accidentally brushed the garden hose against the bumper, causing a small scratch. You can barely see it now, but I can tell it's stll there (it sucsks, coupe was only 1 day old). Saturday, I went out driving. Got home and there was a ton of pollen on my car. It was about 6 in the evening and I didn't really have any plans, so I quickly washed my baby and pulled her into the garage. My neighbor thought I was nuts ... washing my coupe two days in a row. Applied two coats of Z-2 with Z-6 only after the last coat. I was getting a bit lazy. Sunday morning, I woke up and decided to put another coat of Z-5. All I can say is that I love this Zaino. Never used it before. It's a bit of a hassle, but the results are spectacular. I have a diamond graphite, and the paint is silky smooth and the reflection is awesome. If only the pollen would subside. I also used the Zaino leather conditioner. I spent about 10 hours throughout the whole weekend on my coupe. I don't think I spent that much time all last year cleaning my truck
