Little white spots???
Old Jan 21, 2007 | 08:26 AM
gixxer1000's Avatar
gixxer1000
Default Little white spots???
Hey guys i have these little white spost all over my redline z??? . Looks like left over wax or somehit its tinny little with spots?? IF i rub it hard them come off . How would i go by get these off the car??? and what cause them?? thanks
Old Jan 21, 2007 | 08:30 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Hard water??
Maybe mineral deposits?
An acidic solution should dissolve them, maybe vinegar and water mix?
Old Jan 21, 2007 | 09:43 AM
gixxer1000's Avatar
gixxer1000
really humm?? any other ideas what it could be
Old Jan 21, 2007 | 10:14 AM
bizcotch's Avatar
bizcotch
have you parked your car around any industrial areas??? maybe a body shop...or near a "painting in progress" zone? I once got overspray on my car, however came off using the clay bar.
Old Jan 21, 2007 | 01:40 PM
gixxer1000's Avatar
gixxer1000
i used the clay bar today ... but still have a few spots on the roof ??? hum...
Old Jan 21, 2007 | 07:17 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Originally Posted by gixxer1000
Hey guys i have these little white spots all over my redline z??? Looks like left over wax or somehit its tinny little with spots?? IF i rub it hard them come off. How would i go by get these off the car??? and what cause them?? thanks
It is possible it could be wax residue if it wasn't wiped down thoroughly or bits you have missed then your car has been rained on, depending on the wax, those bits will kind of highlight themselves.
Generally overspray is harder to remove and very consistent tiny round dots.
If it is left over wax it will come off next time you wax.
If you give better details might be able to help a little bit more.
Old Jan 21, 2007 | 09:39 PM
bizcotch's Avatar
bizcotch
mmm....im kinda curious now. Could you post close up Pix using the macro feature??
Old Jan 21, 2007 | 09:47 PM
z350boy's Avatar
z350boy
FYI.........The "white spots" you see are the result of rocks hitting your car. It's a common occurence with Z owners. The best way to prevent them is to have a 3M Bra installed, however that needs to be done BEFORE you get the damage!! If it becomes unbearable you will have to seriously consider a repaint. If you do a repaint that be the perfect time to install a 3M Bra. Cost btw $300- 600 depending on quality, size, application process etc.(that's off the top of my head..confirm before buying!!).
Old Jan 22, 2007 | 07:40 AM
gixxer1000's Avatar
gixxer1000
no they are not rock spots .. It could be let over wax i will take some pics.
Old Dec 4, 2007 | 09:58 AM
BaTMan_4's Avatar
BaTMan_4
do these spots look like white-haze when you look at them from an angle???
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
