How do you clean the Haze off of headlights?
Old May 2, 2007 | 08:39 AM
will56's Avatar
will56
Default How do you clean the Haze off of headlights?
Can someone please help me with trying to figure out how to clean off the haze on my headlights. I dont want to take fine sand paper too it. Has anyone had experience with this and can help me out? thanks
Will
Old May 2, 2007 | 08:42 AM
blasian's Avatar
blasian
Well... I guess this doesn't help you but my roommate wetsanded them down a little and used his Porter Cable and some polish on it afterwards. They came out great.
Eazzy's Avatar
Eazzy
Iv been using a paint buffer/polisher with 3M Finesse compound
Old May 2, 2007 | 08:46 AM
KenZee's Avatar
KenZee
You can find 3M plastic polish at most auto parts stores. It has very a fine abrasive and won't harm the finish. In a bind, I have used brasso, which lists one of it's uses as polishing out plastic watch crystals. It works, but if you have old brasso that is not as liquid as when new, it doesn't finish out as well as a new can of brasso does. The stuff loses moisture over time in the can. Go with the plastic polish if you can find it and put a couple of coats of wax over the lights to protect the new finish.
Old May 2, 2007 | 08:47 AM
Chako135's Avatar
Chako135
i wouldnt use any type of sandpaper..you can go to autozone or another auto parts store and pick up a cleaner for headlights. they have about 3 different types and most of fthem work fine.
Old May 2, 2007 | 08:50 AM
Motormouth's Avatar
Motormouth
the haze on my headlights could not be removed with a liquid compound.
Chako, even Autozone sells headlight haze repair kits that have sandpaper... lol.
I will have to refinish them, by using one of the kits which is (I think) sandpaper then a wet agent, then a polishing compound. I tried the less abrasive method first.
The buffer sounds like a good idea...
Old May 2, 2007 | 08:51 AM
bbs350z's Avatar
bbs350z
do scratches come out of the headlights? i would assume if you buff them good enough and polish them after, they'd be gone
Old May 2, 2007 | 08:55 AM
Eazzy's Avatar
Eazzy
Im speaking from first hand experience---the buffer and the finese III will polish the lens like it was new. I hit mine every couple of months. On bad areas and fine scratchs I use wet paper 600-1200 Grit depending
Old May 2, 2007 | 10:32 AM
Black_Sunshine's Avatar
Black_Sunshine
Take a look at this stuff. I've heard of numerous success stories from people that have used it on their headlights.
http://www.chiefaircraft.com/airsec/...chRemoval.html
Old May 2, 2007 | 10:33 AM
Motormouth's Avatar
Motormouth
yeah, i'm def gonna try that! thanks
Old May 2, 2007 | 10:37 AM
CG350z's Avatar
CG350z
put a nice coat of Meguiars NXT on your headlights,then use a buffer.Works every time
Old May 2, 2007 | 12:44 PM
Thumbs up
Originally Posted by KenZee
3M plastic polish
Old May 2, 2007 | 05:47 PM
solidsnake's Avatar
solidsnake
wish someone knew how to get rid of it on the inside of the light.. *cough, cough*
Old May 2, 2007 | 06:03 PM
Eazzy's Avatar
Eazzy
Old May 2, 2007 | 06:56 PM
Ianmtx's Avatar
Ianmtx
Nice thanks for the ideas guys, gonna try this.
Old May 3, 2007 | 11:50 AM
….without taking the light apart.
Old May 3, 2007 | 06:02 PM
solidsnake's Avatar
solidsnake
lol. i know how to but i was being sarcastic towards a fellow member.
Old May 3, 2007 | 06:18 PM
nzpv03's Avatar
nzpv03
I had an e36 3 series bmw before my z and those lights get ****** hazy... so I just used some crest whitening and a toothbrush in circles and it worked really well...give it a try!
Old May 3, 2007 | 11:35 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Umm, I hope you aren't using NXT on your headlights. Try some Meguiar's Plastx it's designed for clear plastic. And it does work. It makes the plastic look very clear and removes the hazing.
Old Jun 4, 2007 | 09:27 AM
psytropic's Avatar
psytropic
+1 on PlastX
