Claybar on Magnetic Black?
Old Feb 21, 2007 | 10:41 AM
Nero's Avatar
Nero
Default Claybar on Magnetic Black?
hey, i just bought the zaino kit with claybar in it and i have read in a few posts that claybar is bad for magnetic black paint and that it causes marring. can anyone confirm this? i would like a definite answer, thanks
Old Feb 21, 2007 | 11:14 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
No problem - marring is caused by using a dry bar. Simply re-wet the bar and clay over that section again.
Old Feb 21, 2007 | 04:59 PM
Nero's Avatar
Nero
k thanks, i was getting worried
Old Feb 25, 2007 | 09:28 AM
yellowlady's Avatar
yellowlady
Default clay
i just got an 05 in yellow and i have clayed it twice already. clay is ok to use on all car finishes. however be sure to have the least agressive type of clay. if you were to use the wrong grade you would marr the finish. clay magic blue is the best all around clay. they have a red that is very aggressive and would cause you some grief. also, make sure your car is very clean, and use plenty of water, or other lubricant.
Old Mar 14, 2007 | 09:19 PM
Kevin Overall's Avatar
Kevin Overall
The color of the car is not an issue as you are just claying the clear coat, the clay will never touch the actual pigmented paint layer, keep the clay wet and moving at all times.
Old Mar 15, 2007 | 07:15 PM
fresnel151's Avatar
fresnel151
I've used a Clay Magic blue bar on my MB Roadster. Works great - no marring. As said before, keeping it and the surface wet is critical.
Old Mar 15, 2007 | 07:21 PM
ldawg32's Avatar
ldawg32
i have the zaino clay bar as well and it is red. i dont think they have a blue one. is this too aggressive
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
Tochigi_236
Sep 27, 2015 03:40 PM
