How to Safely Deal with Bird Shishkabob
Old Apr 8, 2003 | 07:49 PM
DetailingDude's Avatar
DetailingDude
Default How to Safely Deal with Bird Shishkabob
Each Bird's, uhhh ... "Stuff" has a different pH levels depending on what they are eating. Also, birds don't have a No1 or a No2 hole, they have a No1/No2 hole.... so it is double whammy when it hits your car (urine and feces). To make matters worse many birds use tiny broken up shells or fine gravel to assist them with digestion.
Many oceanic birds eat fish and use shells while many inland birds eat berries and use gravel.
So........ someone that had their paint etched and someone who didn't are testament to the varying pH levels.
Here's a trick for getting Bird Shishkabob off your paint safely: Keep a bottle of Selzer Water in your car. When you see the Pooo, crack open the bottle and pour a small amount of Selzer water onto the mess and allow it to soften it. The bubbles in the water will lift much of the residue. For the remaining matter turn the selzer bottle upside down, with your finger or thumb over the spout shake it vigerously and blast off the bomb (aim away from people, your windows, other cars).
Use a 100% Cotton towel or a Microfiber towel and a Quick Detailing spray to remove the drips and splatters then when you get home properly wash and inspect the area to see there is any minor etching. If there is take the appropriate measures to get rid of it. If there is no aparent damage give it a quick coat of your surface protection.
Old Apr 9, 2003 | 10:31 AM
MikeW's Avatar
MikeW
Good advice. Thanks.
Old Apr 11, 2003 | 03:28 PM
irish-z's Avatar
irish-z
Default bird shishkabob
d-dude
Good advice but a day late!! My SB suffered from a run with a cluster bomb! Three large clusters that I did not discover till the end of my drive. By then the S#&#@ had dried and I removerd the largest damage with soap and water. cleaned up ok except for what looks like etching. Any suggestions on removing/correcting the residule??
Thanks for your help.
Old Apr 13, 2003 | 06:38 PM
DetailingDude
Default Re: bird shishkabob
Originally posted by irish-z
d-dude
Are you actually in Ireland? That will change how you do things as you'll have to resort to Farecla or AutoGlym.
sales@czp
Sep 23, 2019 03:30 PM
