Water Leaking Past Door Seal
Old Mar 15, 2007 | 03:48 PM
drumma022's Avatar
drumma022
Default Water Leaking Past Door Seal
Anyone else have the problem of water leaking past the door seal where the side mirror meets the frame? I noticed this a while back once when going through a crazy rain storm in Miami, but now every time I go through the pressure wash car wash it will leak in, drain down under the door panel enough to leak out of the speaker holes on the door. Its weird since it does not happen on the same side each time.
Old Mar 19, 2007 | 02:54 PM
sumfknguy's Avatar
sumfknguy
yeah... i get the same thing every once in awhile. I think its just the rubber seal. I did notice that as the weather started to warm up it doesn't happen as much... *shrugs*
Old Mar 19, 2007 | 02:56 PM
Starchecker's Avatar
Starchecker
This happened on my roadster. The top needed replacing anyway and they found a problem with the seal on the drivers side, so they replaced all that stuff too.
Now the drivers side is solid, but the pass. side leaks a little toward the front when I wash it.
Of course some idiot cut the rear portion of the sealer on the pass side, but that is a different issue.
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Tochigi_236
Sep 27, 2015 03:40 PM
