Tar On My Black Z...help!!
Old Jul 16, 2007 | 11:06 AM
ryan987's Avatar
ryan987
Default Tar On My Black Z...help!!
There's a ton of development goin on where i live. So unknowingly, i was driving on a VERY freshly paved road. I went to wash my car, and the entire passenger side from wheel to bumper had Tar residue all along the bottom and midway on the door.
How the hell do i get this off without ruining my paint??
Thanks!!!
Old Jul 16, 2007 | 11:08 AM
SuperBlack350z's Avatar
SuperBlack350z
with tar remover. go to your local auto part store.
Old Jul 16, 2007 | 11:09 AM
cavallino33's Avatar
cavallino33
Bug and tar remover, clay bar, polish, wax
LAKERSFAN's Avatar
LAKERSFAN
i found some stuff made by Turtle Wax that works pretty well. I believe its just called bug & tar remover. Use a lot of it and rub gently until it wipes off.
good luck
I originally didnt know that it was tar on my car and tried just using soap and water to take it off and it scratched up the paint pretty good. SO DONT DO THAT!
haha
Old Jul 16, 2007 | 12:15 PM
350Z84's Avatar
350Z84
You can try the bug and tar remover, if not that I would say a mild compound.
Old Jul 16, 2007 | 12:17 PM
sponsorsthisway's Avatar
sponsorsthisway
Clay bar it.
Old Jul 16, 2007 | 12:21 PM
SuperBlack350z
Originally Posted by sponsorsthisway
Clay bar it.
i wouldn't clay bar it right off the back. If the tar gets stuck in the clay, it will scratch up the paint. Try to use the tar remover to get most of it off. Usually spray the tar remover on, let it sit for 10-15 secs, spray off with some water, let it sit for another minute or so and spray with more water.
Old Jul 16, 2007 | 12:32 PM
350Z84's Avatar
350Z84
Maybe, you could try using a hair dryer to heat up the tar and use the tar remover. But don't burn your paint. Kind of the same way you remove badges.
Old Jul 19, 2007 | 11:49 AM
03redlineZ's Avatar
03redlineZ
Clay bar for sure, I just detailed on of my family members cars who had tar caked on the side and it ALL came off with a clay bar....I need to buy a new one now cause its toast but the car looks great!!
Old Jul 21, 2007 | 09:31 PM
MadCabbie's Avatar
MadCabbie
NO CLAYBAR! You run the chance of ****ing up the paint...
I found Turtle Wax Bug and Tar remover on accident. My brother in law had a bottle laying around and I needed some...
Hands down the best iv ever used for bugs
However, for tar and road paint, I have found that "oops" works amazing. Same goes for Goo B Gone. It wont hurt the paint. Put it on a rag, rub the tar off and then clean the paint....
Old Jul 22, 2007 | 05:33 AM
DavesZ#3's Avatar
DavesZ#3
Mineral Spirits or WD40 will help dissolve it. Once you have the majority of it off, wash the area and look for spots that will not come off. Small spots can be removed with the claybar. Do NOT attack a large area with just a claybar!
Old Jul 22, 2007 | 05:51 AM
IndyZ-man's Avatar
IndyZ-man
I've used pretty much the same thing. I had some stuff from PPG called take off and WOW!! Sprayed it on and you could see the tar start melting away. Then just wipe clean. I recently just heard about the WD40. But they say it works pretty good too. Then just give it a nice coat of wax and should be good as new.
Old Jul 22, 2007 | 06:00 AM
Sleeper01's Avatar
Sleeper01
I had the same problem with my car...i used turtle wax Tree Sap remover and it worked great...people also use Goo Gone...but i couldnt find it soo i used Turtle wax looked like nothing ever happen to it.
Old Jul 22, 2007 | 09:59 AM
WD40 fixes everything. Everything.
Old Jul 22, 2007 | 12:14 PM
DavesZ#3's Avatar
DavesZ#3
If you look at the MSDS of most of the "tar removal" products you see that the large percentage of the makeup is mineral spirits. IIRC, WD40 is about ¾ths mineral spirits.
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
