Onr?
Old Jan 6, 2008 | 10:29 PM
Get_Zwole's Avatar
Get_Zwole
Default Onr?
Hey guys im bout to order some ONR so i can wash this remainder of the winter in the garage. When you mix it in your bucket do you try to make suds like reg. carwash soap or do you just stir it till its mixed in then use it like plain water? Sorry for the newb post but i have yet to use it or see it used just see it get praised alot. thanks.
Old Jan 6, 2008 | 10:38 PM
redlude97's Avatar
redlude97
it doesn't suds up like normal wash, its very watery and you only add a very small amount. I like to mix it with warm water to keep my hands nice and toasty while washing in the garage
Old Jan 7, 2008 | 12:50 AM
Get_Zwole's Avatar
Get_Zwole
ok so i just put 2 gallons or however it says to mix it then just kinda stir it so it mixes well then just wash panel by panel drying immediatly? How much do i need on my mit do i need it dripping or should i ring it out to where it wont get water anywhere but where i wipe? thanks sorry again for being newbish thanks for the response though.
Old Jan 7, 2008 | 01:14 AM
redlude97's Avatar
redlude97
This is how I do it pretty much, only I include a 5 gallon rinse bucket to soak my mitts in before redunking in the ONR. http://www.exceldetail.com/NRWStechnique.html
Basically my steps are:
Fill sprayer with water and 1 oz ONR solution
Presoak entire car with sprayer
Fill 2 gallon bucket with water and 2 oz ONR
Fill 5 gallon bucket
Get 2 wash mitts(sheepskin preferably)
Soak mitts in ONR solution, remove and allow mitt to drain so it doesn't drip excessively
Starting with the top of the car, begin washing 1 panel at a time
-I like to wash 1-2 panels at a time with 1 mitt, toss it in the rinse bucket, pick up the second, go over the previously washed panels, then move on to an additional 1-2 adjacent panels.
Dry first 1-2 panels
Wring out mitts and put back into ONR solution
Repeat process moving panel by panel.
Each panel gets 2 wipedowns before drying to ensure the towels stay clean, if they become dirty during the drying process, then you didn't remove the dirt with the ONR. This may not be a problem, but to me its just an extra step that helps ensure no marring occurs.
Old Jan 7, 2008 | 04:04 PM
Get_Zwole's Avatar
Get_Zwole
cool man thanks alot you cleared it all up for me cant wait to get some .
Old Jan 7, 2008 | 04:10 PM
SuperBlack350z's Avatar
SuperBlack350z
This is what one of the best stuff ever made. Even on black, it doesn't swirl or marr up the paint AT ALL. Simply amazing stuff. Gets expensive though because you will be addicted to the stuff.
Old Jan 7, 2008 | 08:17 PM
Get_Zwole's Avatar
Get_Zwole
just ordered the gallon one lole it was 33 bucks. The 32 ounce one was 15.99 so i figured as much as yall praise it i might as well go big . cant wait to try it out this weekend if it gets here.
Old Jan 7, 2008 | 09:13 PM
redlude97's Avatar
redlude97
1 gallon=128 oz's = ~50 washes = <$1 a wash. Thats cheap IMO. It also makes a great quick detailer and clay lube also and even cheaper for those uses!
Old Jan 8, 2008 | 09:44 AM
Get_Zwole's Avatar
Get_Zwole
you can use it as similar to a clay bar? do tell do tell? this **** is just getting better and better in my book.
Old Jan 8, 2008 | 10:12 AM
redlude97's Avatar
redlude97
No, you can use it with a claybar as the lubricant instead of using the expensive quick detailers on the market.
Old Jan 8, 2008 | 07:27 PM
Get_Zwole's Avatar
Get_Zwole
ohhhh ok gotcha i misread that a little thanks.
Old Jan 9, 2008 | 07:20 AM
BriA5's Avatar
BriA5
Just started using ONR this winter and was VERY nervous at first.
I've been very impressed with the results. No marring and my car can finally be clean in the cold! I'm very careful witht he application, though. Two bucket method and lots of water.
I'm addicted to this stuff.
Old Jan 21, 2008 | 07:26 AM
Get_Zwole's Avatar
Get_Zwole
i just used ONR for the first time since getting it last night worked great. I only used one bucket the car was pretty dirty so i would wash one panel dry and go in the house and rinse the mit with the sink till i got all the lose particles out then repeat. Took a little while bud i dont have a grit guard and didnt wanna chance it. Looks and worked great though cant wait to use it again next week .
Detailed Image
Cleaning & Detailing
Jan 28, 2010 08:14 AM
Detailed Image
Jan 29, 2009 11:22 AM
Detailed Image
Jan 16, 2009 09:44 AM
noodleman
East Canada
16
Nov 28, 2008 09:47 PM
