just got new z..help
Old Jun 17, 2003 | 03:56 PM
havabooz's Avatar
havabooz
Default just got new z..help
i finally recieved my car...
i would like to keep this baby in pristine codition...i plan to give it its first wash/wax this weekend
i know all of you think zaino is the best so i will use that
but as far as the hole process goes (of washing and waxing) wat do i do
please give me a step by step..and tell me what brand you use
much appreciated
Old Jun 18, 2003 | 02:08 AM
SteveZzz's Avatar
SteveZzz
If you look here there's detailed instructions for application.
Steve
Old Jun 18, 2003 | 08:09 AM
Showcars's Avatar
Showcars
For a "new car application" of Zaino, here's what I do:
1) Wash car with dawn dishwashing liquid. This will get all the grease/oils off the car. I mix dawn & water in a spray bottle. I wet the car with a hose (car MUST be in the shade), then spray the dawn/water on the car and rub with a clean cotton cloth. I use a bucket of clean water to rinse the cloth (change this water OFTEN).
2) Dry the car. I use an "Absorber" synthetic chamois, then follow up with Zaino Z-6 spray and a cotton towel
3) Clay the car. I mix Zaino Z-7 carwash and water in a spray bottle. I put my clay through a pasta roller to make a "pancake." I spray the Z-7 on a section of the car (about a 2'x2' area) and rub the clay pancake in the wet area. I then fold the pancake in half (dirty-side in) and run it through the roller again. Spray the next area, and repeat....
4) Rinse the car. Use a hose (no nozzle) to stream water over the car to rinse off the Z-7. I'll use a soft cloth to help release anything that is still sticking to the car.
5) Dry again - same as step 2.
6) Apply a THIN coat of Zaino Z-1 (do NOT wipe it off) followed by a coat of Zaino Z-2. Optionally, you can activate your Z-2 with ZFX, which means you don't need Z-1.
(If you use Z-1, insert a 1 hour wait here. If you use ZFX, insert a 15 MINUTE wait here)
7) Wipe off the polish with cotton towel
(if you use Z-1, insert 24 HOUR wait here... If you use ZFX, insert 30 MINUTE wait here)
8) Spray & wipe with Z-6 using a clean cotton towel.
9) Apply a second coat of Z-2. No need to use Z-1 or ZFX.
10) Wipe off the 2nd coat with a clean towel
11) FINAL WIPE with Z-6 and a clean towel.
Old Jun 18, 2003 | 02:04 PM
havabooz's Avatar
havabooz
thanks so much for your responses
