Please HELP!!!! Wheels (Pic)
Old Mar 17, 2008 | 12:45 PM
VO...'s Avatar
VO...
Administrator
Originally Posted by klubhedsi
How do I know if it had a clear coat on the lip...and I only put it on a tiny piece of the wheel and it didnt seem to work so i stopped,
When you apply the metal polish you'll know in the 1st couple of seconds. If the cloth starts turning black on the 1st or 2nd rub, it is safe to use. If it doesn't turn black, stop, you have clear coat....
Old Mar 18, 2008 | 08:43 PM
Willowns's Avatar
Willowns
Well my suggestion is that there is this rubbing compund to polish chrome and alum. that we sell at lowes. now i know that you all are thinking that nothing good comes from lowes...but this **** is powerful. it sold with all the other car cleaning stuff at lowes...it defently works!
Old Mar 19, 2008 | 06:34 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
Originally Posted by ZSpectrum
any tips for the p21s finish restorer application?
Well like any metal polish what you apply it with will make a bigger difference then you might think. A quality microfiber polishing towel will definitely improve your results. One side of the towel is textured which helps get the polish in every little nook. The other side of the towel will help buff off any remaining residue. I apply about small drop to a section of the towel and buff the product in to a small area. I start off with light pressure and use more pressure only as needed. When the product has dried out or the there is nothing more to clean, I flip the towel over to the smooth side or grab a new towel to remove any residue. Here is a picture of my towel of choice:
Sorry there is no short cut with most metal polishes. Elbow grease and hard work with the right combination of products is my method.
Greg @ Detailed Image
Old Mar 20, 2008 | 08:09 AM
Jon70ProofZ's Avatar
Jon70ProofZ
greg ive got clear coated wheels, and one of them has some swirl marks in them that wax and other light polishes won't get out, do you have any ideas what would work best to get these out? i was thinking the finish restorer but since you sell all this stuff i thought i would ask thanks
Old Mar 20, 2008 | 01:38 PM
Detailed Image
Detailed Image
I don't often recommend this but a heavier cutting polish may be your answer. If the wheels are clear coated and you don't like the fine swirls and imperfections in them you may need something stronger. Assuming you used a light cutting polish I would probably try the Menzerna Intensive Polish or other good medium cutting polish. I typically start off with a metal polish then I use the P21S Finish Restorer. If that doesn't work you can progress through light to medium to heavy. Check your results whenever you try new products to ensure you're getting the results you desire. Let me know if you have any other questions.
Old May 18, 2008 | 03:56 PM
KAZ350Z's Avatar
KAZ350Z
Anyone have any reccomendations on a reputable shop to refurbish a rim? One of my Volk SF Challenges has the clear coat coming off and it looks horrible.
Old May 18, 2008 | 04:42 PM
BlueBoxer's Avatar
BlueBoxer
Greg, I did just that this weekend with my Volks and it really brought back a lot of the shine that I had lost. I had some chemical burn through on one, unfortuantely nothing will solve that. I tried the 50/50 vinegar and water, but it was too late for the chemical burn through. Anyways, the IP worked awesome after I clayed it and followed it up with the wheel wax.
Step 1: Clay Bar
Step 2: Intensive Polish
Step 3: Wheel Sealant
If I can get my camera back up and going I will post some before and after pics, but I definately was happy with the results.
Old May 18, 2008 | 04:45 PM
BlueBoxer's Avatar
BlueBoxer
If you don't mind shipping, Velvet Touch in San Diego does great work. They will correct any rubbing, rash, and refinish the lip. 760-846-0942
Old May 18, 2008 | 06:32 PM
Detailed Image
Detailed Image
Step 1: Clay Bar
Glad to hear you were able to find a process that works for you! I'm sure the wheels look a lot better now! Hopefully we can see some pics!
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
