best commercial item to restore clear coat?
Old Mar 21, 2008 | 06:57 PM
tonychu's Avatar
tonychu
Default best commercial item to restore clear coat?
i have a 2003 z and my clear coat is almost all completely gone. if a fingernail is lightly brush over any part of my z it least a scratch. how do i restore my clear coat?
Old Mar 21, 2008 | 06:59 PM
spitfire9200's Avatar
spitfire9200
you get it re-sprayed with clear coat at a body shop
Old Mar 21, 2008 | 07:00 PM
SuperBlack350z's Avatar
SuperBlack350z
that doesn't even make sense. If you have no more clearcoat, then you will need another paint job. Anything can damage clear coat. i can wise toilet paper gently on the paint and it will scratch.
Old Mar 21, 2008 | 07:01 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
I'm guessing you don't realize that clear coat is considered a clear paint? If it's shot, then it's shot. Re-spray.
Old Mar 21, 2008 | 07:08 PM
krnzzang84's Avatar
krnzzang84
just curiouse, how much dose clear coat cost??
Old Mar 21, 2008 | 07:16 PM
spitfire9200
depends on brand, type, amount etc.
Old Mar 21, 2008 | 07:17 PM
Motormouth's Avatar
Motormouth
clear coat value cannot be calculated without a crystalimeterormeter. take a reading and if it's between 10-100 it is about 500 bucks, and anything above is gonna be 1,000+/
Old Mar 21, 2008 | 07:18 PM
spitfire9200
haha
Old Mar 21, 2008 | 07:20 PM
Motormouth's Avatar
Motormouth
for serious.
but yeah, once clearcoat is gone, it's gone.
Old Mar 21, 2008 | 07:23 PM
SuperBlack350z
umm, yeah, you can't just spray clear coat . You will need to repaint the entire car if you want a oem like paint job at least.
Old Mar 21, 2008 | 11:30 PM
Old Mar 22, 2008 | 03:22 AM
ncparamedic's Avatar
ncparamedic
Prodigal Son
^^David, i swear you kill me
Old Mar 22, 2008 | 04:29 AM
n2oZ's Avatar
n2oZ
I used to paint aircraft a few years back so i have quite a bit of time doing this.
Your going to have to respray the clear coat if its pretty much scratching off the car. Factory paint isn't the best job in the world, its orange peeled the paint and clear clear coat are extremely thin as well.
You have two options, sand the car with some 500 grit sandpaper and be careful not to sand through the color and spray or get clear coat sprayed on your ride. For best results and longevity, sand first clear coat smooth (sand out orange peel) and spray another coat. Two coats of clear will give you something to buff on later if it looses its luster over time.
Second option you can be real cheap and buy some 2000 grit sand paper and give the nasty areas a once over till thier smooth, you wont get all the spot off but get it close. Then buff over it using 3M polish, stage 2 then to polish. After this apply some wax and it will look ok but only a few months at a time. A drawlback is you can only do this so many time before your paint is buffed through.
Old Mar 22, 2008 | 05:38 AM
track1z's Avatar
track1z
How to fix your fender.
1-400grit sand paper
2-Take the sand paper and ruff the surface up.Your tring to make the surface area ruff so the clear will stick.
3-If you already have rust or see primer or metal,all is not all lost.
If that accures a few small steps are needed to fix,but i'm going that your not there and your color is still in good condition.
Find a shop that will lay the clear down I wouldn't charge but 50 bucks.Then again I don't live in your state.I could do all the work for 100 bucks.
Old Mar 22, 2008 | 04:10 PM
j.arnaldo's Avatar
j.arnaldo
Hey, guys, how 'bout plain old polishing with a high-quality wax (Prestone's Synthetic???) to make that clear coat last longer? I haven't tried that synth'
yet, but, from the description on the bottle it's outta this world. Will keep you posted when do get around to polishing my beast ('04 Touring Coupe).
Old Mar 22, 2008 | 08:07 PM
SuperBlack350z
yeah, that's not high quality wax. Wax is a sealant that protects clear coat from UV rays and what not.
