Cleaning Headlights and Tailights
Old Jul 11, 2003 | 07:28 PM
jikman01's Avatar
jikman01
Default Cleaning Headlights and Tailights
If you guys have never tried Plexus before try it. You can usually find it at dirtbike shops. It's a spray that cleans, shines, and protects your clear and colored plastics. Keeps them from yellowing with age also. This stuff is fantastic.
Old Jul 15, 2003 | 12:18 PM
johnsZ's Avatar
johnsZ
Default lights
I use the three Meguiar's products for plexiglass surfaces (Number 10, Number 17 and I forgot the third)
There are similar products from 3M and others. These are very mild abrasives in a thin carrier solution. Just wipe on, rub a bit, and wipe off. The different compounds are for different levels of "repair"- from polish to "get out scratches"- so use the right stuff.
I actually recovered some sun-damaged lenses on my van by sequentially going from 1000 grit wet-or-dry to 1200 to 2000 grits, then sequencing the Meguiar's stuff from the repair compound to the polish compound- took a little while, but saved $100's (check the price on the headlamp arrays...)
Old Jul 15, 2003 | 12:55 PM
POWERZ's Avatar
POWERZ
Both Plexus and the Meguiars 10/17 combo are GREAT for plastics! I use Plexus on the headlights of my Z as well as for routine maintenace on my Jeep soft top windows. The Meguiars products are a little more aggressive and should only been used when really necessary. I like to use them on the Jeep windows in the fall to remove all the scratches and scuffs before putting them away for the winter. You need to start with a clean surface though so I usually use Stoner's Invisible Glass first.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
JGee450
Sep 30, 2015 04:32 AM
