NEW!!!! Daily Specials at Detailed Image
Old Oct 4, 2009 | 10:41 AM
  #481
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (October 4, 2009) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Oct 5, 2009 | 02:54 PM
  #482
Detailed Image
Detailed Image
Today's Daily special (October 5, 2009) is Chemical Guys Simply Leather.
Regular Price for 16 oz is $8.99. Today's price is $6.74!
  • Fresh leather smell
  • Spray on fabrics or wipe on interior
  • Eliminates bad smells by breaking down odor causing bacteria
Old Oct 6, 2009 | 09:27 AM
  #483
Detailed Image
Detailed Image
Today's Daily special (October 6, 2009) is P21S Bodywork Conditioning Shampoo.
Regular Price for 500 ml is $9.99. Today's price is $8.28!
  • An excellent, shampoo with high lubricity and gentle cleaners that will not remove your protection
  • Only a cap full of shampoo is needed in a 5 gallon bucket of water
  • The low sudsing formula does not make this a great shampoo for a foam gun
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old Oct 7, 2009 | 05:31 PM
  #484
Detailed Image
Detailed Image
Today's Daily special (October 7, 2009) is Chemical Guys Fade 2 Black.
Regular Price for 13 oz is $12.99. Today's price is $9.74!
  • One of the most unique trim restorers that turns faded trim back to a deep factory black finish
  • Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
Old Oct 8, 2009 | 06:16 AM
  #485
Detailed Image
Detailed Image
Today's Daily special (October 8, 2009) is Klasse High Gloss Sealant Glaze (HGSG).
Regular Price for 500 ml is $20.99. Today's price is $15.96!
Regular Price for 1000 ml is $27.99. Today's price is $21.28!
  • One of our longest lasting sealants that looks best after multiple coats
  • Can be finicky to remove, so we recommend wiping on and wiping off, working in small sections
  • Apply with a foam applicator pad and remove with a quality microfiber towel
  • Properly prep the paint with Klasse All In One chemical polish
Old Oct 9, 2009 | 10:33 AM
  #486
Detailed Image
Detailed Image
Today's Daily special (October 9, 2009) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.87!
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Old Oct 10, 2009 | 07:28 AM
  #487
Detailed Image
Detailed Image
Today's Daily special (October 10, 2009) is Chemical Guys Bare Bones Undercarriage Spray.
Regular Price for 16 oz is $9.99. Today's price is $7.49!
Regular Price for 128 oz is $32.99. Today's price is $25.18!
  • One of our best trim dressings that brings out a beautiful black factory finish
  • Ideal for wheel wells, under carriage, engine bay and any other dark trim pieces
  • To avoid over spray, we recommend misting Bare Bones into a towel, then wiping the trim piece
Old Oct 11, 2009 | 09:09 AM
  #488
Detailed Image
Detailed Image
Today's Daily special (October 11, 2009) is Menzerna PO106FA Nano Polish (Super Finish).
Regular Price for 16 oz is $26.99. Today's price is $20.82!
Regular Price for 32 oz is $49.99. Today's price is $37.49!
Regular Price for 128 oz is $149.99. Today's price is $123.00!
  • Our best selling finishing polish that removes light imperfections and lots of depth and gloss
  • Easy to work with, with long work times and easy removal when properly broken down
  • Most commonly applied with a white polishing pad for a great combination of cut and gloss
  • Can also be applied with a black or blue finishing pad for additional depth and gloss but less cut
Old Oct 12, 2009 | 03:18 PM
  #489
Detailed Image
Detailed Image
Today's Daily special (October 12, 2009) is Lake Country White Polishing Pad.
  • A polishing pad designed to remove minor surface imperfections with an abrasive polish on a buffer
  • Menzerna PO106FF polish is one of the most popular products to use with the white pad
Old Oct 13, 2009 | 05:07 AM
  #490
Detailed Image
Detailed Image
Today's Daily special (October 13, 2009) is Squash Air Giga Vent Clip Air Freshener.
Regular Price is $9.99. Today's price is $7.49!
  • A fresh, unique smelling air freshener that keeps your car smelling great for weeks
  • Attaches to one of your vents for a fresh scent every time you turn on your heat or air
  • JDM squash scented air freshener
Old Oct 14, 2009 | 06:30 AM
  #491
Detailed Image
Detailed Image
Today's Daily special (October 14, 2009) is Leatherique Rejuvenator Oil.
Regular Price for 16 oz is $29.99. Today's price is $22.69!
  • Detailed Image's best leather care product to restore neglected, faded, hardened leather
  • Restores oils and proteins that are naturally found in leather for a soft and supple feel
  • Works best when allowed to penetrate leather for up to 48 hours, ideally in the heat
  • Using a hair drier to heat up the leather surface allows for maximum penetration and best results
  • Apply Rejuvenator Oil by massaging the product into the leather with your bare hands
  • Must be removed by following up with Leatherique Prestine Clean
Old Oct 15, 2009 | 07:35 AM
  #492
Detailed Image
Detailed Image
Today's Daily special (October 15, 2009) is Menzerna Power Gloss.
Regular Price for 16 oz is $18.99. Today's price is $14.24!
  • One of our most aggressive compounds we have to offer, allowing for deep paint correction
  • Most commonly used on a yellow cutting pad or purple foamed wool pad
  • Will leave behind marring and hazing, so it is important to follow up with a less aggressive polish
Old Oct 16, 2009 | 07:49 AM
  #493
Detailed Image
Detailed Image
Today's Daily special (October 16, 2009) is Dodo Juice Time to Dry Drying Detailer.
Regular Price for 250 ml is $12.99. Today's price is $9.74!
  • Dry your paint faster and more effectively
  • Helps minimize adding imperfections during wipe downs
  • Reduce potential water spots on your paint
  • Best used in conjunction with a waffle weave drying towel
Old Oct 17, 2009 | 07:41 AM
  #494
Detailed Image
Detailed Image
Today's Daily special (October 17, 2009) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
  • Very easy to apply and remove carnauba wax that looks great on any color vehicle
  • Includes an applicator pad that conveniently stores inside the top of the wax
  • Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
  • Excess product should be removed with a quality microfiber towel
  • P21S recommends prepping the surface with Paintwork Cleanser for best results
Old Oct 18, 2009 | 07:41 AM
  #495
Detailed Image
Detailed Image
Today's Daily special (October 18, 2009) is Menzerna PO85RD Polish.
Regular Price for 32 oz is $39.99. Today's price is $29.99!
  • When you want the absolute maximum depth and gloss, finish your polishing with PO85RD
  • Works best after correcting paint imperfections with more aggressive polishes
  • Most commonly applied with a black or blue finishing pad when used on a buffer
Old Oct 19, 2009 | 11:32 AM
  #496
Detailed Image
Detailed Image
Today's Daily special (October 19, 2009) is Optimum (OPT) No Rinse (ONR).
Regular Price for 32 oz is $15.99. Today's price is $12.15!
Regular Price for 128 oz is $39.99. Today's price is $31.81!
Regular Price for 8 oz is $7.99. Today's price is $5.99!
  • One of the must haves for any auto detailing enthusiast or professional, simply revolutionary
  • ONR is perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
Old Oct 20, 2009 | 06:18 AM
  #497
Detailed Image
Detailed Image
Today's Daily special (October 20, 2009) is Clay Magic Fine Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
  • Fine grade clay bar that is one of the standards in the industry for enthusiasts and professionals
  • Remove embedded surface contamination that does not come off during the washing process
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old Oct 21, 2009 | 11:38 AM
  #498
Detailed Image
Detailed Image
Today's Daily special (October 21, 2009) is Lake Country Black Finishing Pad.
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
Old Oct 22, 2009 | 10:08 AM
  #499
Detailed Image
Detailed Image
Today's Daily special (October 22, 2009) is Chemical Guys Vertua-Bond 408.
Regular Price for 16 oz is $26.99. Today's price is $20.24!
  • Properly preps your paints surface for applying a sealant or wax to your paint
  • Ensure you achieve the maximum durability out of your protection by using Vertua-Bond 408
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Old Oct 23, 2009 | 07:29 AM
  #500
Detailed Image
Detailed Image
Today's Daily special (October 23, 2009) is Optimum (OPT) Tire Shine.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
  • Water based tire dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
