Brake Dust Solution!
Old Jul 26, 2003 | 12:00 PM
ZULATOR's Avatar
ZULATOR
Thumbs up Brake Dust Solution!
Wax your rims with Meguiars Gold Class Car Wax. It works like a charm. I'm sure any wax will work just as good.
Old Jul 26, 2003 | 01:37 PM
teh215's Avatar
teh215
Really? Have you tried it or are you making a suggestion?
Old Jul 26, 2003 | 01:49 PM
Pat1USMC's Avatar
Pat1USMC
It won't last, trust me...
Old Jul 26, 2003 | 03:50 PM
ZULATOR's Avatar
ZULATOR
It worked for me. It forms the same protective coat like on paint. Of course you have to rewax them like you do a car. I have just over 2000 miles/4 months on my car the brake dust still hasn't re-appeared. All I can say is if you got some wax, try it. You spend more time cleaning them on one occasion than you will waxing them.
Old Jul 26, 2003 | 05:01 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I Zaino my rims every time I do my car. I have multiple layers of Z-2 on them. It doesn't prevent brake dust but it does make it A LOT easier to clean them after it is on.
Old Jul 26, 2003 | 07:06 PM
DMONTE's Avatar
DMONTE
I have tried Maguire and many other waxes on the rims, cannot just hose them off must wiped them off every couple of hours of driving
Old Jul 26, 2003 | 07:10 PM
ZULATOR's Avatar
ZULATOR
I think a lot has to do with how much and how hard you drive your car. A lot of mileage and hard braking definitely increases the amount of brake dust created. I only drive my Z on the weekend (if it's not raining).
Old Jul 26, 2003 | 07:18 PM
ares's Avatar
ares
Veteran
ditto bonz, I used zaino on both stock set and the rays, both get brake dust eventually. comes off just fine, but still comes on.
either I need to start using meguires on the rims, or stop using the brakes so much.
Old Jul 26, 2003 | 07:40 PM
Bobg's Avatar
Bobg
I'll tell you something even better, PAM. That's right, the no-stick stuff put in pans before cooking. Think about it!
Old Jul 26, 2003 | 07:47 PM
krutoydude's Avatar
krutoydude
New Rain-X wheel protectant.
Old Jul 26, 2003 | 07:50 PM
ChadO's Avatar
ChadO
I heard that Crystal Guard works great at preventing brake dust. I haven't tried it yet myself, but I will next week I already wash my car every week so the brake does doesn't get *too* bad, but it would be nice to not have black wheels the day before I wash.
ares's Avatar
ares
Veteran
pam is grease... the brake dust would stick in it like glue... be like dumping glitter on glue.
hehe this isnt a cake.
as for the rainx stuff, Im tryin that, cause the rainX is gold. didnt know the stuff existed tho.
Old Jul 26, 2003 | 09:18 PM
mgl's Avatar
mgl
i tried to buy this stuff but cannot find it anywhere. i looked at kragen and target. any suggestions on where to buy???
Old Jul 26, 2003 | 09:37 PM
MY350Z.COM's Avatar
Ditto the Doc, but I did the same with Crystal Guard, makes it much easier to clean the wheels.
Old Jul 27, 2003 | 03:08 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yeah, I used the CG on my Stealth when I trialed it for Tako and the car still GOT the dust, it was easier to clean off though.
Old Jul 27, 2003 | 07:17 AM
krutoydude's Avatar
krutoydude
Auto Zone is the place to get RainX wheel protectant. All you do is spray it on your wheels and let it dry.
Old Jul 27, 2003 | 07:21 AM
SteveZzz's Avatar
SteveZzz
I've used the Rain-x stuff for the wheels and it certainly reduces the amount of dust that accumulates. However, I found it a bit harder to wipe off the dust that does accumulate then it was when my wheels were waxed with Gold Class.
I used CrystalGuard Quick on the whole car yesterday, including the wheels. I'll let everyone know how that does.
Old Jul 27, 2003 | 01:16 PM
flynnibus's Avatar
flynnibus
Z Flier
Nothing is going to prevent the brake dust... all we can do is make it easier to remove. The brake dust is so fine it will attach to anything.
Waxing the wheels is definatly the way to go.. after waxing washing the rims is more 'hitting all the surfaces' then it is 'scrubbing all the surfaces'.
I waxed.. then didn't.. because first time was a pain... and after a few months, I found it much much harder to clean my rims. After waxing again, its effortless to clean them.
You'll also find the rims get 'stained' easier if not waxed.. which takes more cleaner and effort to remove. When waxed, you can clean the rims with just water and brush typically.
Old Jul 27, 2003 | 03:24 PM
Duke407's Avatar
Duke407
And I thought that I was the only one who drove their Z on the weekends and when it's not raining. My wife tells me that I'm nuts. Whatever.
Old Jul 28, 2003 | 07:06 AM
mdelia's Avatar
mdelia
The car we had previous to the Z was a 98 Passat 1.8T. The Passat's and the Audi A4/6/8's all used the same OEM brake pads which were notorious for shedding break dust. (Take a look at the front tires of any of those cars and you should see what I mean).
When it came time to change the pads on the car, we replaced the pads with Mintex "Red Box" (street) brake pads. The difference was night and day on the amount of dust they shed. Under same driving conditions I could probably go about a week before the stock pads made the rim filthy, where as with the Mintex pads, I could go about a month.
