Cleaning lug nut pockets..........
Old Oct 3, 2003 | 03:45 AM
mrice's Avatar
mrice
Default Cleaning lug nut pockets..........
Im getting quite a buildup of brake dust inside the wheel lugnut pockets, is there an easy way to clean this out?
Old Oct 3, 2003 | 03:48 AM
DMONTE's Avatar
DMONTE
Put a set of hawk brake pads on the front, I did a few weeks ago incredibly less dust and better breaking you most likely can change the brake pads yourself very simple
Old Oct 3, 2003 | 05:11 AM
Lee3Z's Avatar
Lee3Z
Use a soft paint brush and some soap and water to clean inside the luge nuts.
Old Oct 3, 2003 | 07:44 AM
ares's Avatar
ares
Veteran
I use a Qtip
perhaps I should call the Ztips?
hehe I crack myself up.
Old Oct 3, 2003 | 12:03 PM
Kevin Overall's Avatar
Kevin Overall
You can get a brush called a parts washing brush, it is pefect for getting into those areas, try soap and water first with the brush, if that does not work try some Simple Green...
Old Oct 3, 2003 | 02:26 PM
afr0puff's Avatar
afr0puff
I just use a twisted up piece of cotton towel and use that like a Q-tip. I clean my wheels with the same rag, so while I'm down there, I just shove it in the lug nut well and twist it in there a couple of times.
Old Oct 6, 2003 | 01:21 PM
Ralphus's Avatar
Ralphus
OMFG!!11 I UZ MAH WEINAR!!!!11!!
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
samansharif
Sep 25, 2015 12:31 PM
