Chances are you'll learn something new in HUGE detail write up
Old Sep 18, 2009 | 11:39 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
Default Chances are you'll learn something new in HUGE detail write up
Our latest auto detailing article was put together was designed to take you through an entire detail from start to finish while trying to explain the mindset of one of the top detailers in the industry. The detail was performed on a 2006 Acura TL in Nighthawk Black Pearl, some of the softest black paint out there. With nearly 150 photos and 8 pages of explanation, we broke this article up into multiple sections so it would load faster and be better organized to find the information you are looking for quickly and easily.
Here's an overview of what is covered:
Page 1: Overview, Pre-Detail Prep, Washing and Drying
An overview of the detail to be performed
Assessing the easily damaged Acura paint
Starting the detail
Wash the wheels, tires, and wheel wells first
Properly washing soft black paint
Cleaning and washing your exhaust tips
Engine bay detailing
Drying black paint without adding swirls
Page 2: Clay Bar, Polishing, Protecting
Using a clay bar to properly prep the surface
Polishing your paint to a swirl free finish
Measuring the paint's thickness
Properly taping your vehicle prior to polishing
Choosing the right polish
Using the proper amount of polish
Results after one pass of Menzerna Power Finish on an orange pad
Polishing lower panels with problem areas
Removing deep etchings from the paint
Safely polishing the trunk lid
Removing scrapes, scratches and other deep imperfections
Safely polishing pillars
Alcohol wipe down after polishing
Post-polish clean up with ONR
Protecting your paint with a sealant
Page 3: Finishing Touches and Interior
Dressing your wheel wells and tires
Detailing the interior
Start your interior by dusting
Dressing and protecting the interior
Comparing Optimum Protectant Plus to 303 Aerospace Protectant
Caring for your leather
Streak free glass
Don't forget the sunroof
Page 4: After shots of the Acura TL detail
We hope this article improves your detailing knowledge and translates into a better finish for your vehicles.
If you have any questions on anything, please do not hesitate to ask. Let us know what you think!
Enjoy,
Greg @ Detailed Image
Old Sep 18, 2009 | 11:55 AM
CRIDDA's Avatar
CRIDDA
Thanks for sharing. Will check it all out when I get home tonight.
Old Sep 18, 2009 | 12:23 PM
Brrcats's Avatar
Brrcats
purely amazing, good work
Old Sep 18, 2009 | 01:20 PM
sanford's Avatar
sanford
thanks a mill
Old Sep 18, 2009 | 01:55 PM
NismoZ_840's Avatar
NismoZ_840
Wink
Please post "Training your 9year old" DIY Does it work for other ages? . Great write up, results, and reminder to for me to order some tire gel. Thanks!
Old Sep 19, 2009 | 10:13 AM
Detailed Image
Detailed Image
I'm thrilled to hear the article has been helpful.
Greg @ DI
Old Sep 19, 2009 | 08:56 PM
350ZTheStandard's Avatar
350ZTheStandard
Damn amazing as usual, I pickEd up plenty of small tips that will make the difference. When i am polishing my Z, I am only using a minimal amount of polish 3 samll dots of polish & they can cover a complete panel. In the write and tips for polishing you are using a so much more polish than myself, I was under the impression that I am only using a minute amount of polish to reduce the un-necessary waste, I am getting nice results & the buffing is minimal. Realistically how much polish should I be using & how often shoulfd I be adding more polish to the foam pad??
Old Sep 20, 2009 | 06:36 AM
TSC17's Avatar
TSC17
Thanks everybody for the compliments on the work and the article. I'm happy to hear that you're finding it helpful.
Training the 9 year old was easy...it's the adults that I have a problem with!
Originally Posted by 350ZTheStandard
Damn amazing as usual, I pickEd up plenty of small tips that will make the difference. When i am polishing my Z, I am only using a minimal amount of polish 3 samll dots of polish & they can cover a complete panel. In the write and tips for polishing you are using a so much more polish than myself, I was under the impression that I am only using a minute amount of polish to redude the un-necessary waste, I am getting nice results & the buffing is minimal. Realistically how much polish should I be using & how often shoulfd I be adding more polish to the foam pad??
Thank you!
3 to 4 small dots for most polishes is typically all you need...some require more, and some polishes require less. In the photo that you're referring to, please keep in mind that it was a fresh pad. I'll typically use a little more on the first few passes before the pad is primed. After that the amount can be reduced as you have residual polish built up on the pad. For a door panel for instance, I typically break it up into 2 or 3 workable sections (depending on the size of the door).
For polishes like Menzerna and Optimum, a little goes a long way. For something like Megs 105 however, I will go through a lot more to achieve the desired results.
I hope this helps!
Todd Cooperider
Old Sep 20, 2009 | 07:25 AM
always_wright's Avatar
always_wright
Addicted
Wow, awesome write up! I'm definitely looking into ditching the PC Random Orbital and picking up a rotary. Because I've been using the orange pad and Menzerna Power Finish and to achieve the best results I had to do a few passes, which is super time consuming. Do you suggest the Makita?
Old Sep 20, 2009 | 07:50 AM
TSC17's Avatar
TSC17
Thank you!
Yes, the Makita is the standard in the business...a real workhorse! It has good ergonomics, and the variable speed trigger is a plus as well.
Old Sep 20, 2009 | 07:54 AM
Detailed Image
Detailed Image
I personally would definitely recommend the Makita 9227C-X3 Rotary Buffer. You can start at a very low RPM and relatively safely work it in. I'm pretty sure Todd would make the same recommendation but he can let you know his thoughts. Also don't forget to check out our DI Packages Makita 9227C-X3 Starter Kit where you get a great set of pads at a discounted rate.
Greg @ DI
Old Sep 20, 2009 | 08:04 AM
always_wright
Addicted
Thanks for the input, hopefully I can order one sometime soon! I actually have the backing pad and 2-3 of every color of pad from Lake Country, so I should be set!
Now all I need is an air conditioned garage....
Old Sep 20, 2009 | 11:55 PM
67ZNISMO's Avatar
67ZNISMO
Awesome write up as usual. I'll be placing another order with DI hopefully in a few weeks. I too am using a flex orbital but thinking about picking up a Makita to get the job done faster. Thanks DI!!
Old Sep 21, 2009 | 09:39 PM
Detailed Image
Detailed Image
Glad to help and I'm happy to hear you have a lot of the products you need.
Thank you for the support I'm confident you will aboslutely love the Flex. It's an amazing tool that you are going to love.
Greg @ DI
Old Sep 22, 2009 | 05:08 PM
metal_gear350's Avatar
metal_gear350
wow...simply wow...so the problem with my shine is not my technique but my car!!!I need an Acura TL. Great job such detail
Old Dec 28, 2009 | 08:19 PM
dragonfire6's Avatar
dragonfire6
Default ...
Excellent write-up with amazing results!
Old Dec 28, 2009 | 09:04 PM
stevezcar's Avatar
stevezcar
nice write up
Old Dec 29, 2009 | 03:04 AM
mw9's Avatar
mw9
Nice write up and a great company. Always answers every question I have. Thanks again.
ablaine
Nov 29, 2016 10:13 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
