WD40 can clean very well
Old Mar 28, 2010 | 07:27 PM
NismoZZ's Avatar
NismoZZ
Default WD40 can clean very well
My Z's engine had gotten dirty and most parts are fairly easy to clean but the intake manfold is prob the hardest since im not going to buy one anytime soon i decided to clean it i tryed some soap an hot water nothing i was going to go to autozone to buy something but i just looked around an tryed some WD40 it works very well you can see the dirt an grime get removed right away an it also says on the can can be used as a cleaner. i did not take before pics but here are some after pics so works good just dont use it when your engines hot.
Attached Thumbnails WD40 can clean very well-dsc02439.jpg   WD40 can clean very well-dsc02440.jpg   WD40 can clean very well-dsc02441.jpg   WD40 can clean very well-dsc02443.jpg   WD40 can clean very well-dsc02420.jpg
Old Mar 28, 2010 | 07:49 PM
BLK Z33's Avatar
BLK Z33
That looks good man, I need to try it next time I detail my Z. Thanks for the info.
Old Mar 28, 2010 | 07:54 PM
WD40 is a simple petroleum distillate with 1,000 uses. Very sharp. How many miles on the motor?
Old Mar 28, 2010 | 08:03 PM
NismoZZ's Avatar
NismoZZ
just turned 38,000 today
Old Mar 28, 2010 | 08:31 PM
Just checking if you were trying to trick us with a 5,000 mile garage queen
Old Mar 28, 2010 | 08:36 PM
ImWeeZzel's Avatar
ImWeeZzel
hmmm, im gunna try this i have my car. thanks for the idea
Old Mar 28, 2010 | 09:01 PM
cubs4worldseris's Avatar
cubs4worldseris
thanks man. i'm gonna try this next time i detail the engine bay.
Old Mar 28, 2010 | 09:05 PM
SatchScream's Avatar
SatchScream
Those are some great results, gotta love WD-40.
Old Mar 28, 2010 | 09:11 PM
adamciya350's Avatar
adamciya350
This is great, I actually recently got some oil on my intake manifold and have been meaning to clean it, thanks for sharing! Don't mean to be Buzz Killington, but you should probably get a heat shield/box for the intake, its probably sucking a ton of hot engine air in that location.
Old Mar 28, 2010 | 10:05 PM
_Donovan_'s Avatar
_Donovan_
I love WD40, When I was in Iraq I always used WD40 to clean my MK19. Worked better than anything else.
Old Mar 28, 2010 | 10:53 PM
Mike@Blackline's Avatar
Mike@Blackline
top notch results amigo
Old Mar 29, 2010 | 07:49 AM
Blu Hvn's Avatar
Blu Hvn
Hot Rodders for several years have used WD-40 to shine up their engines and chrome for car shows. I use WD-40 to get road tar and bug juice off also.
Old Mar 29, 2010 | 12:12 PM
driftmc's Avatar
driftmc
Wow that is shining real good there. Good job~ & thanks for the tip
Old Mar 29, 2010 | 12:27 PM
Ronin82's Avatar
Ronin82
damn that looks good. did you spray everything including hoses and if you did, did you just manually wipe everything down?????
Old Mar 29, 2010 | 12:30 PM
TPete19's Avatar
TPete19
Is it safe to use around painted surfaces?
Old Mar 29, 2010 | 04:02 PM
MOB's Avatar
MOB
Wow thanks man
Old Mar 29, 2010 | 04:14 PM
cdoxp800's Avatar
cdoxp800
2000 uses for WD40
http://www.wd40.com/files/pdf/wd-40_2042538679.pdf
Old Mar 29, 2010 | 05:25 PM
jv350z's Avatar
jv350z
I need to do this. Thanks for the tip!
Old Mar 29, 2010 | 07:44 PM
NismoZZ's Avatar
NismoZZ
no i didn't spray everything the hoses i clean with a product called back to black using a cloth. the only part i used WD40 for was for the intake manifold an i didn't spray it to much i didn't want to get it all over the place. i just sprayed little sections at a time. Then wiped away the dirt with a cloth Im afraid of any kind of liquid getting into any kind of electrical connection how this helps
Old Mar 29, 2010 | 07:50 PM
ZPHILE's Avatar
ZPHILE
Originally Posted by cdoxp800
Thanks for this above and to the OP!
