Brushless Car Washes
Old Nov 13, 2003 | 06:12 PM
2Fishy4U's Avatar
2Fishy4U
Default Brushless Car Washes
Since I got my Z in April of this year I have always washed the car by hand based on the many recommendations on this board. However, winter is coming to Wisconsin and I wondered what you all think about taking the car through a brushless wash.
In part, what prompts my question is the State uses so much salt that perhaps the car wash would do a better job of removing the salt from the underbody.
I do not plan to drive the Z in ice and snow, but nonetheless I am sure the car will give some salt on it.
Your thoughts.
Old Nov 13, 2003 | 07:03 PM
ares's Avatar
ares
Veteran
how much can it hurt? tho I remember last winter, people in snowy areas put those little lawn sprinklers under their car to clean it
Old Nov 13, 2003 | 07:21 PM
afr0puff's Avatar
afr0puff
Avoid the ones that are operated by a pressure plate inside tire rails. They will scratch up your rims if they aren't wide enough. I've seen it happen to too many wheels.
Old Nov 13, 2003 | 10:12 PM
mrZeee's Avatar
mrZeee
the only prob I can think of is that most car washes recycle water... which means that every car going thru is washing salt off and getting sprayed with recycled soapy salt water..
Old Nov 14, 2003 | 03:33 AM
SungNamZ's Avatar
SungNamZ
Default Re: Brushless Car Washes
Your thoughts.
I'm a Territory Manager for 7 units in NM and CO. I used my units until I installed the CAI. Just to much pressure on the unit through the grill. It will do an excellent job on the underside. Also, if you must drive on a "plate" to activate, stay to the right. That way the outside of your rims will not come in contact with "plate" frame. If the one you use does not have doors, take someone along to help guide you the first few times. I do not use "recycled" water, but "yes" some do. Good Luck!
Old Nov 14, 2003 | 06:50 AM
Beaker02's Avatar
Beaker02
I worry about gettingmyrims scratched up and somebody breakingoffmy rear wiper on drying. That's what keepsme out.
Old Nov 14, 2003 | 06:51 AM
Beaker02's Avatar
Beaker02
Wow. The computer i'm on hasa space barproblem.
Old Nov 14, 2003 | 12:37 PM
zh.guitar's Avatar
zh.guitar
Leave your mark!
I use one on a regular basis and have no problems. Definately watch the driver's side rim if you have to dive over the plate. It is an easy thing to avoid if you are aware.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
