Review on Mr. Clean AutoDry
Old Dec 31, 2003 | 02:40 PM
  #41
Conceyted's Avatar
Conceyted
Originally posted by MSOsr
After using it for the 3 washes covered by the "test" unit, I'm a little disappointed with the AutoDry. The deionized mist works well, but the soap seems to leave a "film" on the car.
After using the unit, the surface of the car was not slick (in spite of all the Zaino). I washed it again with my regular carwash soap and dried it with a Big Blue waffle microfiber towel, and the surface was again like new.
The deionized water is a good idea, but I'm not sold on the polymer soap the unit requires.
Agreed with that. I am no longer impressed or using this product.
Old Jan 2, 2004 | 08:48 AM
  #42
kbsig106's Avatar
kbsig106
Default Finally got mine!!!
Damn - almost 3 whole months and I finally received mine two days before Christmas. Since I'm not a Zanio user, I'm pretty happy with my 1st two washes. I can see how it would affect a Zanio product.
So I give the product a "B". It has saved me some time on drying since I had received some bad scratches from micro towels - I'm just bad at keeping them clean.
So I can take it or leave it. I guess it will all depend on the cost of the filters and extra soap.
Old Mar 18, 2004 | 02:35 PM
  #43
ChrisMCagle's Avatar
ChrisMCagle
Default Best thing since sliced bread
Well, I'll ressurect this thread...
I bought one from Target about a month ago and must say that it's the BEST thing I've ever bought to clean my car. It does exactly what it says it will do, although like was mentioned in a previous post, the final rinse does come out in a fine mist which is somewhat of a pain to use, but it does what it says. I am very disappointed by the fact that you have to pretty much buy a new bottle of soap for every 2 1/2 washes because you use a full fill-up per wash and I actually run out most of the time. The filters that come with the unit when you buy it are only good for "3 uses", but I am on my 4th so far and it still hasn't turned "brown" like they say and the water is still drying without spots. At least the replacement filters say they are good for 11 uses.
Overall I would HIGHLY recommend this to anyone who HATES drying their car as much as I do. Just wash it and walk away. It's that easy!
-Chris
Old Mar 18, 2004 | 04:38 PM
  #44
Conceyted's Avatar
Conceyted
I will say this one more time, then its all on you guys. Worst thing i ever did was use this. It strips zaino.... horrible product...
Old Mar 18, 2004 | 07:02 PM
  #45
pargion's Avatar
pargion
Default autowash
I think that the prevention of water spots comes from the deionized water and not really the soap. (the ions in the water are dissolved, but then crystalize on your car when the water evaporates...using deionized water eliminates the origin of water spots) has anybody tried using just the rinse and NOT the soap....making sure to rinse off all the tap water that was used to rinse the soap with the autodry spray?
Old Mar 18, 2004 | 07:04 PM
  #46
pargion's Avatar
pargion
Default Re: autowash
sorry, i meant using a different soap other than the one that the kit comes with, like zaino Z7
Old Mar 18, 2004 | 07:07 PM
  #47
Conceyted's Avatar
Conceyted
read how the system works... the soap acts as a water sheeting mechanism (using a sheeting polymer in the soap) and the deionized water sheets off and evaporates... either way its crap
Old Mar 19, 2004 | 06:30 AM
  #48
ChrisMCagle
Hmmmm.. perhaps you have a good point. I used the Autodry yesterday to wash my car and I never really noticed before, but my car is not as "shiny" after I was it as it is when I use regular old car wash soap.
The other thing I noticed is the very first time I used it, the sponge that I used, which originally was bright white, had turned black! Not dirty brown... BLACK. Considering my car is Superblack, I was a bit concerned that it actually was taking paint off, but when I re-read the instructions that came with it, it did mention in the Q&A section about the sponge or rag being extra dirty and their explaination is that the soap is great at removing dirt. Perhaps that's not the only thing it is removing???
I retract my previous statement about it being a great product, but I think that I will try what pargion said and use regular soap, and then just the filtered water. It's worth a shot anyway.
-Chris
Old Mar 19, 2004 | 08:02 AM
  #49
bixby's Avatar
bixby
Do you think this will work well on my non-Zainoed black Expedition? That thing is a beast to dry. In warm weather I have to wash & dry in sections to prevent spoting. It's pretty shinny now (Permaplate every 6 mos) & I'd like to keep it that way. Eventually I do want to claybar it & add Zaino but man that is going to be a full weekend project when I get around to it.
Old Mar 19, 2004 | 09:35 AM
  #50
pargion's Avatar
pargion
Default Re: Re: autowash
-Chris
The reason your car is not as "shiny" is probably because the Mr. Clean soap stripped all the polish/wax that your Z originally had on it. It seems that it's pretty harsh on cars considering it takes off enough stuff to make sponges black! yikes!
Anyway, I feel that my theory on using just the autodry rinse was a bit vague, so I'm going to clarify a bit:
1) wash with a soap of your choosing
2) rinse with regular tap water from the hose
3) rinse the remaining tap water from the hose with the autodry spray/rinse thing. make sure you get off all the remaining tap water by working from top to down and using sweeping motions and not just spraying randomly
4) polish/wax the car as you would normally after it dries
this is all just speculation, but it's based on my knowledge in chemistry (which i studied in undergrad). also, i'm not telling anyone to do this...it's merely a suggestion that I feel would work better than the original product. good luck
Old Mar 19, 2004 | 10:49 AM
  #51
ChrisMCagle
Default Re: Re: Re: autowash
pargion,
I think that it may work because I remember several years ago, I bought this thing (similar to the Mr. Clean Autodry) that attached to a hose and just de-ionized the water and claimed to make it dry without spots (actually worked too). You would still wash the car with regular car wash soap (didn't matter what kind), then you would spray off the car, and then attach this filter thing and spray off the whole car.
I'm gonna try it when I get home today. It just sucks because I bought a brand new bottle of soap yesterday.
-Chris
Old Jul 29, 2004 | 11:34 AM
  #52
KShep's Avatar
KShep
For those considering using this...stuff, bump
Old Jul 29, 2004 | 11:49 AM
  #53
ChrisMCagle
Wow!! Back from the dead.
Do NOT use this thing. It strips Wax, Zaino, ect. It actually does exactly what it says in that it cleans the car and dries without spots, but it kills the shine and removes all the paint protectors in the process. Not good... don't use.
-CHris
Old Jul 29, 2004 | 12:28 PM
  #54
HotRodGuy's Avatar
HotRodGuy
Originally posted by Conceyted
Wrong. You can only use the mr clean wash in the object sprayer. If you wash the car with different wash and only use the rinse, it will still bead water. The mr clean wash has a dry sheeting polymer in it that makes the water sheet off of the car, thus less chance of spots. If you dont use the mr clean wash you wont get the spot free guarantee they advertise.
if you are only using it to basically dry your car you should try this method
http://www.autopia.org/forums/showth...?threadid=5120
Or even go to a hardware store and pick up a soft water connector
hulkout
Apr 28, 2017 09:00 PM
nanotech
Oct 2, 2015 05:02 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
