water stain on lips
Old Jul 20, 2011 | 05:02 PM
JDMStanced's Avatar
JDMStanced
Default water stain on lips
The lips of my racing hart rims are covered with water stain. i purchased the rims used. Dunno what they are made of.
I tried Mother's Mag & polish, Meguiar's hot rim cleaner (purple), and soap and water. None of them worked.
How do i get rid of them?
Old Jul 20, 2011 | 05:11 PM
mr. sparco's Avatar
mr. sparco
Clay bar with detailing spray should do it. The lips usually have a clear coat over the polished aluminum. Trying to polish the clear coat with Mother's Mag would only damage it. Unless the original owner had the clear coat removed due to age, then Mother's Mag would work.
Old Jul 20, 2011 | 05:14 PM
JDMStanced's Avatar
JDMStanced
hope i didn't mess it up with Mag.. didn't look closely but it did shine a little after Mag use lol
Could you tell me how clay bar will get rid of super strong water stain? (looks like water stain, not sure if IT IS water stain)
i thought clay bar is used to get rid of small particles on the paint
Old Jul 20, 2011 | 05:45 PM
mr. sparco's Avatar
mr. sparco
Water spots/stains are caused by chlorine/metals/particles/brake dust etc. It's on the surface of the clear so the clay bar will work fine. If the lip is clear coated. If it's straight aluminum, once again Mother's Mag.
Old Jul 20, 2011 | 05:50 PM
JDMStanced's Avatar
JDMStanced
i'm going to SmartWax open house so i'll pick up some clay bars there.
This is little off topic. Which product should i use to clean wheel surfaces and lips when they get really dirty from chit from the road and brake dust? Some times it's hella hard to clean with soap and water.
Old Jul 20, 2011 | 06:33 PM
This thread needs some photos.
Old Jul 20, 2011 | 06:42 PM
JDMStanced's Avatar
JDMStanced
i thought i posted, my bad
the surface is rough where the stains are
Old Jul 20, 2011 | 06:56 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Looks like the previous owner had already wet sanded them, then realized that it's a pain in the *** to keep "homemade" refurbished lips blemish free. Ask me how I know
Old Jul 20, 2011 | 07:33 PM
JDMStanced's Avatar
JDMStanced
if that's true, then
is there a way to fix this myself without using buffer machine?
i never done this kind of work. i don't even wax my car lol
Old Jul 20, 2011 | 08:58 PM
mr. sparco's Avatar
mr. sparco
^ This is too much for you to tackle.
Old Jul 21, 2011 | 07:52 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
The majority of that should buff out no problem with a quality metal polish. The P21S Finish Restorer or the P21S Metal Polishing Soap should work great. Let me know if you have any questions.
Greg @ DI
Old Jul 21, 2011 | 10:27 AM
JDMStanced's Avatar
JDMStanced
Arent they same as Mother's metal polish that i tried?
Old Jul 21, 2011 | 10:31 AM
Detailed Image
Detailed Image
No mother's makes an okay polish, these should be a deeper cleaning. The P21S Finish Restorer is the deeper cleaning option so that may be your best bet. I'm pretty confident it should remove most of that stain, but certainly you never know for certain until you try. I use this each time I have a bad stain on the wheels, exhaust tips, trim, etc.
Greg @ DI
Old Jul 21, 2011 | 03:07 PM
JCITY's Avatar
JCITY
The best stuff for this problem is a paste product called A-MAZ.
I got it at a glass place.It takes off water stains on everything.Works great on tough
water stains on windshields etc.
The label says:
PACIFIC SUN MAKERS,INC
SACREMENTO,CA
1-800-921-6861
It will take off your water stains.
Old Jul 21, 2011 | 03:12 PM
JDMStanced's Avatar
JDMStanced
not sure...i prefer to use the product specifically for rims
Old Jul 21, 2011 | 03:42 PM
JCITY's Avatar
JCITY
I've used on wheels...label indicates use on wheels,boat fiberglass etc.
FYI--I checked online...available from many sources.
search A-MAZ
Old Jul 21, 2011 | 06:26 PM
Appears that the clear coat is gone.
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
PureR3d
Sep 10, 2015 06:23 PM
