Is the paint/clearcoat of Liquid Aluminum thicker or better?
Old Feb 22, 2004 | 05:38 PM
BeavisNuke's Avatar
BeavisNuke
Default Is the paint/clearcoat of Liquid Aluminum thicker or better?
For an $1100 optioned paint job I would expect the paint process to be better, no?
Old Feb 22, 2004 | 05:50 PM
ares's Avatar
ares
Veteran
unlikely. Id think of it as more of a "limited edition" Z with a limited production of that color.
Old Feb 22, 2004 | 06:20 PM
BeavisNuke's Avatar
BeavisNuke
the dealership told me otherwise, but I want a definitive answer from someone who doesn't want to sell me a car
Old Feb 23, 2004 | 07:35 AM
Reese's Avatar
Reese
I have nothing to compare it too, but overall i would say the paint is no more durable. I have 3100 miles on mine and i am so glad i had the clear bra installed cause i already have several rock chips where the bra doesn't cover. I also opened the door into my bass boat yesterday and the paint seems to chip really easy on door edge .
Old Mar 11, 2004 | 06:58 PM
herbrock17's Avatar
herbrock17
Hmmph...on www.nissanusa.com when building a 350Z, even though I chose the Daytona Blue color, that $1100 extra for the "liquid aluminum" option is available on the Touring model?? What exactly is it, if anyone knows?? Is it silver paint, i.e. aluminum, or is it a nicer clear coat over the blue color I want?? Sorry if my questions are retarded...I'm a NOOB and saving up for my Z...see signature below!!
Old Mar 11, 2004 | 07:15 PM
2003z's Avatar
2003z
I read they use some special 'cross hatch' primer on it, but other than that, it doesn't look that spectacular. I thought it would have been like the show car of 2002.
Old Mar 11, 2004 | 08:39 PM
alindo's Avatar
alindo
The color is actually silver.
Old Mar 16, 2004 | 03:58 AM
gooters's Avatar
gooters
Never ever believe a dealership. Most of those salesmen only know a fraction about the Z comopared to the average "my350z" member.
Old Mar 16, 2004 | 08:13 AM
BeavisNuke's Avatar
BeavisNuke
duh... but I still haven't gotten a definitive answer here
Old Mar 16, 2004 | 11:47 AM
Kevin Overall's Avatar
Kevin Overall
Its probably a special paint process, could be a three stage paint instead of a two stage, Corvette has two special colors that are optioned colors that use three stages including a tinted rather than clear clear coat.
BTW, "thick" paint is not really a good thing.............
Old Mar 16, 2004 | 02:20 PM
BeavisNuke's Avatar
BeavisNuke
Explain? I had a Subaru WRX and the paint was awfully thin; it scratched incredibly easily.
Old Mar 16, 2004 | 04:31 PM
Reese's Avatar
Reese
I have looked up the formula for Liquid Aluminum in several aftermarket brands of paint and there is nothing 'special' about the formula its just silver with a little black in it. Unless the aftermarket paint manufacturers just haven't come up with the correct formulation yet, i would have to assume that this is a limited production color for Nissan.
what kevin means by thick paint is when paint is applied heavily then you get texture or orange peel effect. Plus as more and more coats of paint go on a vehicle you lose some adhesion properties. All paints scratch easily, some colors show the scratches better than others. You can get paint that is more durable but the appearance qualities diminish. Also, thin paint does not make it scratch easier, it may seem so since when you scratch it, you can see the primer or metal. The molecular bond of the paint is what prevents scratching. Paint manufactureres could make paint that is harder to scratch but this means its also very tough to buff, which means it must be applied perfect. Which it is nearly impossible to paint a car without getting some kind of debris in one spot and it would be very hard to remove. Don't worry one of these days the parts will just be impregnated with the paint and no matter how many scratches you have the color will still be there. After a collision the panels will just be removed and replaced with panels the same color. I
Old Mar 16, 2004 | 05:29 PM
Kevin Overall
As Reese said, thin or thick has no bearing on how easy it scratches, all paint has scratched fairly easy since the EPA took the lead out of paint years back.
Thick paint is basically unstable on the surface and actually chips and cracks way easier than a good flat smooth paint finish.
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
